Question about Air Tools & Compressors
Test kcm511 - Air Tools & Compressors
Steamer does not work
Possible problems:
- no water
- heating element burned out
- switch defective
- leak in steamer system
If it's out of warranty you'll have to open open it up and test with a multimeter.
May 06, 2012 | KitchenAid KCM511 Coffee Maker
Coffee machine is not heating up
First of all check the fuse in your machine and/or plug (if fused) and replace it. If fuse is okay then look for any melt/loose wires/connections in the machine.
Jun 01, 2011 | KitchenAid KCM511 Coffee Maker
Coffee Lid
www.shopkitchenaid.com
You will probably need to buy the whole thing (jar and lid) for about $25.
Mar 07, 2010 | KitchenAid KCM511 Coffee Maker
ERR CODE WONT WORK
Returning to Target may be a possibility, but is subject to the store's individual return policy.
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
May 25, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid mod#KCM511 - error 2
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Feb 14, 2009 | KitchenAid KCM511 Coffee Maker
I dont have a manual for my Kitchen Aid Coffee makers. Im not sure how to set the time and how to set an auto timer to go off. Help?
If it's KCM511, follow this link =>
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KCM511&siteCd=KAD
If not that model, you should be able to navigate to your particular model. =>
http://www.kitchenaid.com/custserv/service.jsp
Good Luck!
Dec 27, 2008 | KitchenAid KCM511 Coffee Maker
Air Tools & Compressors Logo
26 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
