Homemaker hmwm8000 how do i get coins out of the machine under the agitator? .... kids left coins in pockets when school clothes striaght into washing
jsrock516
  • 5911 Answers
SOURCE: removing agitator
Sometimes small articles of clothing can manage to get between the inner spin basket and outer wash tub. This is NOT common, however. If this were the case the memory stick you mentioned, would end up lodged in the drain pump. There would be a noticeable noise from the impeller hitting it and it may cause the pump to fail, resulting in drainage problems. More than likely, its right where you suspect it is. To remove the agitator, do the following:
1. Remove the center cap or dispenser from the agitator.
2. Under the cap or dispenser is another plastic cap with a pull handle on it. Lift this cap out by pulling straight up, exposing the agitator mounting bolt.
3. Loosen the agitator bolt using a socket and ratchet. Once removed, grasp the entire agitator assembly by the bottom flanges and lift straight up. The entire agitator should come out.
NOTE: When reinstalling the agitator make sure you DO NOT overtighten the mounting bolt or it can cause damage to the agitator and restrict the movement. Good and "snug" is the rule of thumb.
Searspartsdirect.com has an excellent exploded view diagram of your agitator and components if you need a good reference. Just type in your COMPLETE model number and look under the "Agitator, Basket and Tub Parts" heading.
I hope you find what you're looking for and hope this helps you in some way. If you require additional assistance, please let me know.
Posted on Sep 26, 2008
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
srsrs_1999
  • 9 Answers
SOURCE: Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Posted on Apr 30, 2009
  • 82 Answers
SOURCE: Homemaker HMWM8000 shows E2 error and will not
Maybe just a blocked filter?
If the waste pipe is clear and nothing in the filter, the pump is worn or faulty.
Remove waste pipe and lay it flat on the ground to drain.
Hope this helps
john
Posted on Aug 28, 2009
GE washer making scraping noise as it agitates, but clothes are clean and spin is normal
remove the agitator and check underneath for bra wire , coins , and any othering that are left in pockets
Aug 20, 2016 | GE Washing Machines
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
All washing machine have lint filters to protect the pump, but they generally have quite large holes and although called 'lint' filters, they are to stop baby socks and coins getting into the pump. They are always at the bottom of the machine behind the front kick panel on a front loader or under the agitator on a top loader.
If your washing comes out covered in lint, you need to find the item that is shedding it. May also be paper tissues left in pockets. We only have one item that sheds lint and that is a bathmat. We wash it separately.
Take a look at this video.
Washer Filter Plug Kit part 285868 How To Replace
May 26, 2016 | Whirlpool Washing Machines
Top loader. Why are there grinding noises underneath during agitation?
probably foreign objects like buttons, bra wires, coins and anything else left in pockets
remove the agitator and clean out
Jan 23, 2016 | Maytag Washing Machines
Coins
It might well be a coin! Coins and other items that fall from clothes pockets into the drum stay in the drum. They are too large to pass through the small drainage holes in the drum. But my granddaughter found a way! She opened the washing powder dispenser at the top of the machine and dropped three coins (that we know about) into the drawer and closed it. The water fill cycle then somehow swept the coins down into the drum. To get them out I had to dismantle the machine and remove the pump outlet assembly and poke a stiff wire into the drum and drag the coins out. The machine is a completely different make to your but I would assume a similar method would work. good luck
Dec 31, 2013 | General Electric GTWS8655DMC GER 5.0 DOE...
Clothes stuck under the agitator
I have the same problem with clothing getting trapped under the agitator. Strings from Hoodies, apron strings, bra straps be caught under it all the time. There is a gab between the agitator and the tub. I have owned the machine for about 3 months, I like it in all other respects but this is crazy!! I have never had a machine that did this. GE needs to address this and fix this issue. It is NOT a matter of making sure your pockets are empty before washing, anything that is thin such as a strap or a string gets caught!! I would think twice about buying this machine if you are looking to purchase it. I don't think this machine will last as long as my others, and I don't think I would recommend this machine due to this very annoying issue.
Jul 17, 2012 | GE Washing Machines
I am in Perth WA and I need a fan belt for my washing machine as it snapped my washing machine is a Homemaker HMWM8000. I would like to know where I can purchase the belt and the price. Thank you,
Hi, I have the same problem. I rang KMart who advised they don't stock washing machines anymore but gave me the manufacturer's number which is 1300 366 155. I rang them and they said it is probably a generic belt which you could purchase from most repair shops, but you can purchase them through Homemaker. They were going to charge me $20 and it would take 7-10 working days to deliver. I am trying to source locally (Albury, NSW) as it may be cheaper if it's generic.
Hope this helps.
Apr 27, 2011 | Washing Machines
MY BEKO MACHINE IS CONSTANTLY FILLING UP WITH WATER AND WHEN THE WASH FINISHES IS STILL FULL OF WATER.iT IS 15MTHS OLD
Probably something blocking the drain, likely to be something left in a pocket like a coin or sweet wrapper (if you have kids). Don't know the ins and outs of this model but should be simple to trace the drain pipe. Some washing machines have an easy access filter point where anything that shouldn't be in the drain get caught. Warning though, you will need to empty the washing machine of water first or you'll flood the floor!
Oct 15, 2010 | Washing Machines
I have a LG WM2016CW washing machine and there is change (penny,nickle,dimes ect.)stuck in the drum some were, how do i get them out?
You said "stuck" in the drum somewhere? Like under the agitator vanes? You should be able to take the lid off the agitator, it should either clip in or have a screw holding it on, and there you will see the nut, or keeper that holds the agitator on the motor shaft. Remove that clip or nut and you can lift the agitator out of the washer. From there you will see all of the wash drum and should be able to remove any foreign objects. If these "coins" are between the inner and outer tub, then you will have to remove both the top cover and lid, and remove the agitator and the inner drum to get to the outer drum in order to reach these objects. Not a hard job, but it will take you a little while. You could try reaching with your fingers around the agitator bottom and see if you can "feel" the coins or objects and possible use a small brush or stick or popsicle stick to move them out so that you can reach them, Kinda like "fishing" under the refrigerator or the couch. In the alternative, you could enlist four friends and unhook the washer from the water supply and the electric, and turn it upside down and try to shake the coins or objects out the top of the drum. Tilting the machine to one side will let them fall to the cabinet sides and possibly drop out the bottom when it is uprighted. Now I know why Mom always "checked" my pockets before she washed Dad and my clothes. We left a little of everything in there, from time to time. Good Luck with this.
Sep 27, 2009 | LG WM2688HWM TROMM SteamWasher
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Sep 13, 2009 | Washing Machines
Clothes keep getting caught under agitator
Check that the agitator is settled correctly on its guide. it shouldnt have sufficient gap to drag clothes under ( unless its kids sock) It sounds as if it has come loose and lifted itself up.
Aug 29, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
