Question about Nortel Networks NORTEL DJ1412A03 ETHERNET ROUTING SWITCH 1612G MANAGED
What is the nortel 1612g default password - Nortel Networks NORTEL DJ1412A03 ETHERNET ROUTING SWITCH 1612G MANAGED
Nortel T7316e Mbox Locked, reset password
The system administrator must reset your password - it will default to 0000. advise if you are the system admin.
Oct 19, 2017 | Nortel Lands Phones
Password forget... what can i do?
Do the factory reset and change the password from the default, unless an administrator's handling it for you.
Jul 25, 2011 | Nortel Passport 1612G Ethernet Switch
I don't know teh default password for NORTEL ERS4526T-PWR AL4500A13-E6
all nortel sw default pass is username rwa pass rwa. please try this and let me know
Feb 25, 2011 | Nortel 4526T 24-Port Gigabit Ethernet...
What is the command to see Sh version on nortel If u have some extra commands for nortel please share
try using
show sys info -- 'll display version
show sys perf -- 'll display cpu and memory utilization.
Dec 18, 2010 | Nortel Passport 1612G Ethernet Switch
I want show commands of nortel 1612g switch
Show config is used to check the configuration of running config!!!
Sep 04, 2010 | Nortel Passport 1612G Ethernet Switch
How to recover a lost password on a Nortel SR 1004
There's no way that you can restore a lost password of your router. The only way you can do is to reset it to factory default and you must know the default username and password of your router. Some of the router manufacturers uses: admin for username and pass for password, some just leaves the password blank but put admin for the username.
Jan 05, 2010 | Nortel Secure Router 1004
Nortel Admin Password Problem
You use the f985 to reset the password. But i cannot publish the password here. It is in your vm manual.
Aug 09, 2009 | NorStar M7324 Telephone
I forgot my password
Find and depress the reset button on the bottom/back of the unit to hard-reset the router to factory defaults. Note: this will lose all user configured options but will set the login for the router back to defaults. Check your owners manual for the default login and configuration options.
From what I have been able to research on this router, the username and password for this router may be:
USERNAME: sysadmin
PASSWORD: nortel
But this information is unconfirmed.
Mar 04, 2009 | Nortel Networks BSGX4e Business Services...
Nortel norstar
ON NORTEL DO A FEATURE 983 PASSWORD IS GOING TO BE 120000 AND THAT WILL PROMPT YOU THRU RESETING THE PASSWORD IF THAT DOES NOT WORK DO A FEATURE 985 PRESS 9THEN TYPE IN (RESET SM ) THEN TYPE IN (PSWD) AND IT WILL GO BACK TO DEFAULT . PS THE SM STANDS FOR SYSTEM MANAGER
Jan 25, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel Networks NORTEL DJ1412A03 ETHERNET ROUTING SWITCH 1612G MANAGED Logo
93 people viewed this question
Top Nortel Networks Computers & Internet Experts
David Payne
David Payne
Are you a Nortel Networks Computer and Internet Expert? Answer questions, earn points and help others
