Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Whirlpool french refrigerator Model MF 12569VEB2
Whirlpool GI6FDRXXY07 I have defrost water on floor
I don't know your particular model but it is usually the same thing each time. The defrost water flows into a drip pan to be evaporated off to the atmosphere by the heat of the compressor. Look for the pan it has probably either been dislodged or has a crack in it from being made brittle from the compressor heat.
Sep 07, 2014 | Whirlpool Refrigerators
Maytag panel flashing and flapper keeps popping
The same thing happened to my frig, also a french door model. I am told this is a known problem on my model MF 12568AES. I called Maytag on their 800 number, mentioned I knew this was a problem they knew about. They denied any knowledge of it, so I told them it was the high voltage board, the (2) 35w 680uf capacitors and they had a technician at my house within 2 days and although they didn't make that same board any more, they sent mine in for repairs. Over 30 days later it was re-installed and it works great. There was no charge for the service calls. My fridge is 8 years old. You can also read info from http://applianceguru.com/forum1/13035-1.html#ixzz2ghTCinxG. In there is a temporary fix until the board is repaired or replaced.
Apr 09, 2014 | LG LRFD21855 Stainless Steel French Door...
WHIRLPOOL REFRIGERATOR FRENCH DOOR ENERGYSTAR 5 MO OLD SAYS COOLING SYSYEM OFF ?
STOP! Don't worry about the other responses- it is SO simple to fix. You just press the two right two buttons (lock and measured fill) at the same time and hold for 3 seconds. That's it!!
May 23, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Last night my daughter replaced filter in my Maytag French Door refrigerator Model MF 12569YEQ Serial Number KY1014173, THIS AM WHEN I TRIED TO USE THE WATER DISPENSOR , WATER SHOT ALL OVER THE PLACE. wHAT...
Your product may have two model numbers, one for the engine and one for the platform. You have entered an engine model number
Since I can't bring up which refrigerator you have, I will have to give you general guidance.
Check to make sure that the filter was replaced the right way, usually an arrow indicates the direction of water flow. Unfortunately, some times a filter that is installed in the reverse position will blow the seals
Jun 04, 2011 | Maytag Refrigerators
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Whirlpool Gold refrigerator w/french doors, model GI5FSAXVY. The door on the right is set higher than the other, not allowing me to open my cabinets above. How do I adjust the height of the one...
you might be able to get a little room
look at the bottom hinge of the door
the one you want to lower
you should see a few spacers between
the bootm of the door and the top of the hinge
as well as being able to lower the hinge pin by screwing it down
Oct 11, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
