Question about Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel Aquasmart
Im getting the error 240 if anyone knows what that one is please?
5 Suggested Answers
  • 713 Answers
SOURCE: I have a Fisher & Paykel AquaSmart top loading
Hi just read your posting.What cycle are you using for the towels?Have you tried a cycle with the EFFICIENCY turned OFF?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Jul 27, 2010
  • 4 Answers
SOURCE: my aquasmart fisher and paykel
Sounds like the 'lid lock' has shorted out. They're not completely waterproof and have seen pins completely blown out inside them. Should measure 73 ohms (or very close to it) across the terminals. Hope this helps.
Posted on Feb 26, 2011
  • 6277 Answers
SOURCE: Is becoming progressively worse with
Sorry, I do not know this particular model- are you certain that it does not have a filter?
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
richroth
  • 9472 Answers
SOURCE: Fisher & Paykel error code 9
Take a look at this document.
Posted on Nov 09, 2012
Last month my aquasmart had fault code 130 payed repairman $180 to fix it now it has fault code 105 your webpage is very unhelpful knowing whats wrong with my aquasmart which is less than 5 years old
Did you look up your manual to help with the problem?
AquaSmart2 8kg - this is a link to download your manual
The good thing is that if you got Fisher & Paykel to come out, they offer a warranty on their service - so call them again and tell them the situation - they should come out for free....
Sep 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Mar 19, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Fisher and Paykel Aquasmart wl80t65c Logo
13 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
