Question about Coffee Makers & Espresso Machines
Caffitaly coffee machine: Water not flowing through coffee capsules
Hi there the water pressure seems to be non-existant in our caffitaly coffee machine. From one day to the next the machine will not pierce through the bottom of the capsules to allow the water to flow through the capsule, however, if I remove the capsule, the water flows through the machine no problem. What can I do to fix this?
Richie_asg1
  • 1036 Answers
SOURCE: Krups FME2 will not flow water.
Does it sound like it is boiling water at all?
If it is boiling, but not giving hot water, then the one-way valve is stuck.
If it is not getting hot (on the soleplate base) then usually the element has blown.
These machines use the steam generated by boiling as a means to move the water up - like a geyser, and need the heat to move the water.
Replacement elements are available, and the valves usually just require cleaning.
Posted on Jun 29, 2008
SOURCE: increasing water flow rate
YOU CAN LOWERET PRESSURE ON THE WATERPOMP.
Posted on Sep 16, 2008
  • 4090 Answers
SOURCE: Dolce Gusto coffee machine hot water not flowing
use a solution of Bicarbonate of soda to clean scale from delivery pipe 1 tsp in 200ml
Please rate my help++++Thanks for using FIXYA
Posted on Jun 03, 2010
SOURCE: Le Cube: Water does not flow after tank in Le cube ran dry....
Open the lever (the one on top of where you put the pod, and keep pressing it backwards until water comes...
Posted on Oct 04, 2010
SOURCE: No coffee comes out, only
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
Posted on Dec 13, 2011
My caffitaly S 23 does not dispense hot Millikan after the coffee has dispensed. Just hot steam and a little bubbly hot water. I have cleaned it it and will dispense milk and the next cup doesn't.
First; I am NOT a Caffitaly repairman. Though I have worked on mini espresso machines. Sputtering and/or poor steam is an indication that your brewer is not up to brewing temperature.
** Most of these home machines have a very small boiler or tank. They are designed to produce hot water and sometimes steam to brew a small 'European' espresso. Here in the USA we like our coffee weaker and with lots of 'other' things mixed in. The 'Americano' is the same amount of coffee but with a lot of hot water added. This amount will tax the small boiler to it's limits. Top it off with a grande latte would be probably be beyond it's ability to completely froth/heat this amount of milk. When you order a Latte from a Barista you will note that it takes a while to froth a Pitcher of cold milk. They are using a large espresso machine and probably pulling a double shot of espresso. To make a similar drink with any home machine requires doing everything 'double' or twice brew. (3 times?) You will need to check the 'ready' light to make sure the brewer is up to heat prior to brewing your next cup.
** Suggest brewing a regular size or 1/2 a mug of coffee-latte then come back again later for another fresh hot cup.
Aloha! ukeboy57
Dec 21, 2017 | Coffee Makers & Espresso Machines
Caffitaly manual
Hi I have a caffitaly modal so1hs/po1hs , I having a prom with mine , the water dos not go into cup I have cleaned it twice and still , it's doing the same thing need help please thanks Julie Donnelly
Oct 23, 2013 | Coffee Makers & Espresso Machines
Caffitaly coffee machine is continually beeping
The Caffitaly Machine Beeps when it needs Descaling...the reduction in the water flow is an indicator that your machine badly needs this maintenance procedure to be completed. Refer to Page 15 of your User Manual.
Sep 30, 2012 | Dualit Coffee Makers & Espresso Machines
When the machine is on and the heating has completed, pressing the buttons to make coffee has no effect. They just blink once and nothing happens. The steamer seems to work fine tho.
This happens to us sometimes and we find that the problem is with the capsule holder. Try taking the capsule holder apart and then twisting it together again. If it's not quite in the right position, the machine will not dispense the coffee!!
Oct 28, 2010 | Gaggia Caffitaly K111 Coffee Maker
My capsule / pod holder is broken. Where can I get a new one, and how much do they cost ? Thank you
hi,
contact ylavoie@sybco.com. they are located in canada and are the distributor for caffitaly. they have a model called ocs3000 that has exactly the same capsule holder.
ciao
Sep 26, 2010 | Gaggia Caffitaly K111 Coffee Maker
When i turn on the machine, green light is on, pod inserted, but the coffee wont come down into cup. This happened before, apparently it was air locked. i tried the coffee button and the steam button at...
When I have this problem with my machine, it is usually because the two parts of the capsule holder are not fixed together properly. Take it apart and then twist it back together again and make sure the handle is pulled all the way down. This part of the machine is very fussy and you might have to do it a couple of times. The machine will not dispense coffee if the capsule isn't seated properly!
I usually find my machine is less noisy after it has been de-scaled. We were told to de-scale every 4 weeks to keep the machine running well. Good Luck!
Aug 25, 2010 | Gaggia Caffitaly K111 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
