Question about Refrigerators
Admiral hmg 21124
Freezer is working but the refrigerator part will not cool.
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Posted on Oct 24, 2009
  • 572 Answers
SOURCE: Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Posted on Feb 10, 2010
AndreaBl
  • 218 Answers
SOURCE: i have admiral refrigerator HMG 21164 and it is
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Posted on Jun 11, 2010
heatman101
  • 43501 Answers
SOURCE: Admiral / HMG 23173 /
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 07, 2011
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
My freezer has ice and fridge does not cool. Admiral signature model HMG 19802. Any ideas
Sounds like you have a defrost problem. First thing check if you fan motor in the freezer is running. You can open the freezer door and press in the door switch and listen to the fan motor. if fan motor is running, you have a problem in the defrost system. if not, you have a bad door switch or fan motor. (not very common)
to test defrost system: Locate defrost timer (under front kick plate) and rotate slowly until you hear a click.After a few minutes you will start hearing crackling sound and see water flowing down the drain line.
if defrost is working, replace the defrost timer. if not, you either have a bad defrost heater or def. thermostat. best think is to replace both.
for more accurate instructions, we need more detailed description of problem
Feb 02, 2015 | Admiral Refrigerators
Admiral / HMG 23173 / 10690324HQ. Motor running. Freezer cooling but not freezing. Refrigerator cool - not cold. Not sure age of refrigerator. Internet says 1964 or 1988 - so probably 88 since house...
heatman101
Jul 06, 2011 | Admiral Refrigerators
MWe have an Admiral hmg 21176 the freezer is working ok, but the bottom fridge is not. It's too warm. We unplugged it for a day and it seem to cool as always, but then returned to the warmer temp. Just...
Assuming your evaporator is completely frozen, I would defrost the coils with a hair dryer, the clip off the defrost thermostat on top of the evaporator coils. Strip and short the wires together, then check if defrost works, if so, order a new one .
Jun 22, 2011 | Admiral Refrigerators
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice maker on Admiral HMG 62165 side by side
Apr 12, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
