Question about Hayward H Series Pool & Spa Heater Electronic Dual Ignition 250,000 Btu Natural Gas H250ed2
Hayward heater blowing fuses1&2
Display blank & fuses 1&2 blown. Replaced transformer & blew fuse 1&2 again
    Top Expert:
  • Hayward Master
  • 6,498 Answers
Shorted ignitor replace
Posted on Mar 19, 2016
4 Suggested Answers
  • 170 Answers
SOURCE: looking for a 3amp fuse for a hayward pool heater
any automotive or electronics store
Posted on Jan 17, 2010
  • 990 Answers
SOURCE: when the unit powers up it blows the fuse at the
If the smoke got out of it it's bad. ;-)
Most transformers are 110v and 220v be sure how you are wiring it. I this is a Hayward heater you can find a book for it at
http://www.haywardnet.com/inground/products/manuals.cfm
Their are a couple of different heaters but they should all take the same transformer. I would go ahead and find the correct heater and print the book so you have it.
Once your sure of the wiring make sure you have the proper power going to the unit. To say if it is kicking the breaker you may just be getting half the power to come back on. Then unhook the transformer from the heater and see how much power you have. If your not getting a full 24v you may have burnt half the transformer. This means a new transformer. If it is still kicking the fuse you need to check all the wiring to the box and make sure that your problem is not there. If it's not kicking the fuse and you have good power, It will be in your heater and you will have to go through that to check for shorts. Your book will have a trouble shooting flow chart to help with this. Good luck.
Posted on Oct 17, 2010
  • 5245 Answers
SOURCE: hayward pool heater display reading AC
Hayward error codes shows AC is blower vacuum switch closed
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
Hayward pool manuals:
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Posted on Oct 15, 2012
Pentair mastertemp 400 no pwer to display. Replaced display. Transformer problem?
Check your control fuse. If the control fuse is bad replace it w/2 amp fuse. The old board could have blown the fuse. If the fuse blows again DO NOT increase the fuse size. Instead find the short in the control circuit.
Jan 21, 2017 | Pentair Pool & Spa
I have Hayward H400IDL2 heater I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater blower comes
Good Day, missed your post for a few days. #1 & #2 fuses are on the high voltage side. This could mean a problem with incoming voltage or a bad fuse or main circuit board. Call our tech line at 908 355-7996. I have attached a link to the manual. http://www.hayward-pool.com/pdf/manuals/H-seriesLowNOx-H250IDL2-H350IDL2-H400IDL2.pdf
Aug 24, 2014 | Hayward H400idl2 400,000 Btu Low Nox...
I have Hayward H400IDL2 heater 6 years old. I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater
Hi, this is John the Hayward tech. If you are now seeing the #4 fuse go that is on the low voltage side. I would guess the main circuit board. I left a manual on your other post.
Aug 24, 2014 | Hayward Pool & Spa
Blown 24v Slow Blow Fuse
Scott, I have the exact same problem. What ended up fixing this? Thanks! - Paul
May 10, 2013 | Honeywell Triangle Tube Prestige Solo 110...
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Transformers and fuses keep blowing
If you are where it's warm and you are using air conditioning, have the technician check the coil in the relay in the outdoor unit. I replaced 2 transformers before I figured out the coil was shorted out and drawing too much current.
Jan 04, 2008 | Goodman GMS90703BXA Heater
RCA RS2656 Shelf System
Had a problem with a customer's stereo system, i replaced the transformer and put in two new fuses and all worked good again. Another time it was a damaged capacitor allowing full charge to go through causing the fuse to blow immediately so i just replaced the capacitor and the fuse and all was good.
Dec 31, 2007 | RCA RS2656 Shelf System
Hayward H Series Pool & Spa Heater Electronic Dual Ignition 250,000 Btu Natural Gas H250ed2 Logo
114 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
