Can send faxes they can read fine but when i get faxes cant read them about a week ago paper jamed in the roller do i need to clean with what product
When people send me a fax on my 190 i caqnt read it does the drum have to be cleaned and do you use alcohol thanks mitch
  • Office Equip... Master
  • 6,168 Answers
I assume you talking about a panasonic DP-190? Do not clean the drum you may gently wipe it down, realize the drum puts the image on the paper, nick it, grease from hands, ,etc will effect copy qualilty. Remove the toner cart. clean any toner spilled. Drum may need replacement, print a toner/drum resupply form to see if the machine prints them cleanly
Posted on Aug 09, 2009
I am Bruce of BLACK SPOT, I have a Pavilian dv7-4170us Entertainment Notebook bought 5 weeks ago. Pluged into my Brother HL-1440 printer and it worked fine for a few weeks. Now I cant print anygthing; I...
Either the paper sensor is broken (if it was stuck it'd always think it had paper) or the pickup roller needs maintenance.
Start by taking a lint free cloth moistened with distilled or bottled water and wiping then drying the paper pick roller really good.
If you can get your hands on some Rubber Renu, that's the best stuff in the universe...dunno why they discontinued making it...maybe because it turned plastic to oatmeal...did wonders on rubber though!
Another trick is to pour a tiny amount of rubbing alcohol onto a piece of paper where the pickup roller goes and quickly putting it in the tray and trying to print.
Keep telling the printer to resume or keep resetting the printer and sending another job til it feeds the paper. The alcohol cleans and moistens the roller until it's evaporated restoring the grip of the pick roller.
Clean any other rollers you can reach either with the lint free cloth or q-tips and bottled water or rubbing alcohol.
This should FixYa right up.
If it doesn't, the clutch may be gone in the printer, and you have a real problem. (that' or it's that darn sensor).
Mar 02, 2011 | Brother HL 1440 Laser Printer
Can't send fax, can only receive
you can't send the fax, the paper don't feed, you need to clean the paper path the roller that guide the paper to pass under the the scanner must be cleaned with alcohol. you need to unplug the fax from the power source. after cleaning wait for 10mn and try to send a fax.
Dec 23, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I cannot send faxes or make copies with my Brother intellifax 1270e. When the paper gets to the read point sensor it stops and says "press stop button" . The machine will receive fine and print...
Cleaning the Scanner
Before cleaning, unplug the power cord for safety. Clean the white roller and the glass
strip under the roller with isopropyl alcohol on a lint-free cloth. You'll need to lift the
two release levers to release the white roller; be sure to lock them in place when you're
through.
During cleaning, I recommend you unplug the power cord for safety.
Brother fax-back system (USA Only)
Brother Customer Service has installed an easy-to-use fax-back system, so you can get
instant answers to common technical questions and product information for all Brother
products. This system is available 24 hours a day, 7 days a week. You can use the
system to send faxes to any fax machine, not just the one from which you are calling.
If you can't resolve difficulty with your fax machine using this manual, call our
fax-back system, and follow the voice prompts to receive faxed instructions about
using the system, and an index of fax-back subjects.
The Brother fax-back system number has been preprogrammed on One Touch key
Dec 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Jammed fax; cant open door
there should be green or red tab to open this door
May 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Minolta fax machine 2800
clean rollers with alcohol, it should pick up ( for a while) rollers will probably need changing
Feb 11, 2008 | Minolta MF1600E Plain Paper Laser Fax
73 people viewed this question
jasbo
jasbo
