Question about Gladiator Freezerator Top Freezer Refrigerator
HOW to get to top of drain tube of Whirlpool gladiator GAFZ21XXMK00
Drain tube of freezer is plugged with ice causing ice buildup in freezer.
    Champion:
    Habit-Forming:
  • 275 Answers
Firstly it's probably blocked by a piece of corn or a pea or something similar, you have to totally defrost the unit by unplugging it, removing all the frozen food, then remove shelves, leave the freezer door open & leave overnight to dry out. Now tilt the unit back & wedge something under the front to hold it there, slowly poor very hot water towards the rear of the freezer compartment in the centre, it should not take long to clear the drain hole, you should be able to see it now, if you have any thin curtain wire or something similar, then gently poke it down the drain hole till cleared continue to use hot water till flowing, careful there will be a fair bit of water coming out the back, keep a few old towels handy, Good Luck.
Posted on Nov 29, 2013
5 Suggested Answers
SOURCE: ice buildup in the freezer. dripping from above refrigerator area
I have had water/ice down the back of a Gladiator as well. I just emptied it, disassembled the back wall of the upper portion of the unit. Just a few screws, and one has to disconnect a wire harness, and then after removing styrofoam and yet another panel, I was able to locate the drain hole. It was frozen solid. As I have hot water in the garage, I sprayed some in the drain hole area and then in the lower portion to get rid of some of the ice. After alternating several times (and removing the lower panel on the back of the unit), I was able to see a free flow of hot water from the drain tube at the lower back of the fridge. I have towel dried everything and have a fan on it now so that it is very dry before starting back up. I am guessing that the drain tube starts to freeze in the winter months (I am in Wisconsin), and then just has no way to thaw as it is sandwiched in the back wall of the unit. This winter I may try some extra insulation. Good Luck!
Posted on Jul 21, 2009
  • 244 Answers
SOURCE: ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Posted on Nov 21, 2009
heatman101
  • 43501 Answers
SOURCE: the bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 27, 2010
bobicehouse
  • 1524 Answers
SOURCE: My Gladiator refrigerator/freezer has had
http://www.fixya.com/support/r9112933-diagnosing_refrigerator_defrost_problems
Posted on Jul 07, 2011
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
An intermittent stream of water from the back top center shroud in the lower freezer section of our Gladiator Ref/Freezer is causing a lot of ice in the freezer. What's wrong?
This is caused by a design flaw in Gladiator Freezerators. The problem is caused whenever the auto-defrost cycle is active. This causes the frost on the coils to melt and flow to the drain tube. If the tube is blocked by ice having formed inside, the water has nowhere to go except down into the freezer compartment where it aagain freezes and forms an iceberg. The solution is to defrost the drain tube but this is only a tempo fix, because eventually it will freeze again. A more permanent solution is to remove the rear cover in the top compartment and expose the cooling coil and the defrost heater. Carefully wrap a 2-3 ft. long piece of bare copper wire, about 14-12 ga. several turns around the defrost heater and extend it down the drain tube located at the bottom right hand side of the drain tray. The little bit of heat transmitted down this wire is enough to keep the tube from refreezing. This fix is now available as a kit that Sears uses to take care of this problem but their kit does not work as well as the above. Good Luck!
Nov 14, 2010 | Whirlpool Gladiator Refrigerator
My refrigerator leaks from the ceiling of the fridge from a center console connection to the freezer located behind the fridge light/lamp. Why is that happening? It leaks significantly leaving a puddly...
You have a problem with either the defrost system or the drain tube in your freezer it plugged. Remove the contents of your freezer and remove the freezer's back panel. If you see that the cooling coil is a block of ice, then you have a defrost problem. Typical problems with the defrost system are the heating element burning out and failing or the defrost timer failure if your refrigerator is an older model. If you see a pool of ice buildup on the bottom of the freezer section, your drain tube might be plugged. That can be fixed by using a hair dryer to melt the ice and use a turkey baster to flush the tube clear. Hope this helps you.
Nov 04, 2010 | Whirlpool ET8WTKXK Top Freezer...
Clogged Drain in the fridge causing ice buildup
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 12, 2010 | Whirlpool 20.9 cu. ft. Top Freezer...
The bottom freezer portion of my gladiator freezerator forms ice
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
Jun 13, 2009 | Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water from the freezer falling in fridge
Usually this is a Door seal problem or a blockage between the frig and freezer compartment. There is usually a Tube that allows water from the defrost cycle to drain down to the pan beneath your unit. If there is ice, food particles, etc blocking that will cause water to enter the frig causing the mess. Listen for a fan to be running inside the freezer....if you hear none, than this may be causing the ice buildup that melts when the unit goes into defrost. If you unplug the unit, take the back panel off inside your freezer you will see coils and the ice. Leave unit unplugged to defrost the freezer and drain tube.....It should work normally when you plug it back in. If not, then you have a defrost heater or thermostat, or control board problem that needs to be checked by a technician.
Nov 29, 2008 | Whirlpool Refrigerators
Gladiator Freezerator Top Freezer Refrigerator Logo
314 people viewed this question
Top Gladiator Refrigerators Experts
christian nielsen
Brian Coughlan
Charlotte Sharp
Charlotte Sharp
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
