Question about Dryers
Hooverlightflashing water leaking at the bottem of the tumbledryer
    New Friend:
    Problem Solver:
  • 9 Answers
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Posted on Nov 25, 2013
Fit bottem entry inlet valve
WATER PRESSURE SWITCH MAY BE FAULTY
Dec 03, 2014 | Washing Machines
Leaking and saying overflow
it could be the air sensor for water level but more detailed info would help. is it still going through all cycles even when it leaks out and is water still being put in? or is it empty going through the cycles?
Mar 28, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore elite model 110.27062604 leaking on the bottem, loud noise when spinning
I have a Kenmore elite top loader s/n 110.27062604 its leaking water out of the rotor only when its spinning
Feb 21, 2013 | Washing Machines
The unit iis leaking water from the bottem and I need a manuel on how to unhook the pipes
As long as the leak is out side don't worry about it.. They all do it .
Jun 25, 2011 | Heating & Cooling
Water is coming from the bottom
Take off the panel at the bottem of dishwasher and find leak. If leaking from water supply connection try to tighten it first. If that does not work turn off water under sink and replace warter supply line. You can get a easy to handle braded line at you local hardware store. Replace other leaking parts at www.repairclinic.com.
Mar 24, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Water leaking from the bottem of double door refrigerator
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint HSS25GFP Side by Side...
TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Feb 17, 2010 | Zanussi Dryers
GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dryers Logo
51 people viewed this question
Top Dryers Experts
