Question about Brother MFC-5440CN All-In-One InkJet Printer
Changing ID on out going fax
We just moved and want to change the ID on our out going faxes with our new fax number.  How do I do this?
  • emax Oct 10, 2007
    Thanks for the advise.  It worked fine.
  • 832 Answers
Press menu then arrow-up-button machine displays 0. setup press menu. Now you will be asked if you like to change your no. press 1 for yes. After changing no. press menu then stop
Posted on Oct 10, 2007
  • Mix-it-up
    Mix-it-up Oct 10, 2007
    sorry: after displaying 0 setup press menu then arrow-down-button to 3. id change press menu etc.
SOURCE:
I want to fax from new zealand to australia. how about i do it...........
In the setup you should enter your the fax number in the internationally standardised format, i.e.
in accordance with the following strict sequence:
??  The "+" (plus) character (by pressing
key)
??  Your Country Code( "64" for New Zealand)
??  Your local area code minus any leading "0"
??  A space
??  Your number on the local exchange, using spaces to aid readability as appropriate.
1 Press Menu/Set, 0, 3.
2 Enter your fax number (up to 20 characters).
Press Menu/Set.
3 Enter your telephone number (up to 20 characters).
Press Menu/Set. (If the telephone number and fax number are the same, enter the same number again.)
Note
??  You cannot enter a hyphen in the number.
To enter a space press once between numbers.
??  The telephone number you enter is only used for Cover Page features.
4 Use the dial pad to enter your name (up to 20 characters).
Press Menu/Set.
5 Press Stop/Exit.
Note
If the Station ID has already been
programmed, the LCD will ask you to press 1
to make a change or 2 to exit without
changing.
3.Station ID
??²
Now dial the fax number of australia 0061............ and send fax.
Jun 02, 2011 | Brother IntelliFax-2820 Laser Fax
I want to change the name (My caller ID)when I fax how can I do that It show up as Holy Dreams that name of our former company. I want it to show as our new company. How do I do that
I believe you wish to change the "Station ID" on your MFC-240C. This setting will print out your company name and other header info on your faxes:
1) Press the <Menu> key
2) Press <Up> or <Down> Navigate to "Initial Setup"
3) Press <OK>
4) Note: Your station ID is already set, therefore the machine will prompt you to choose: (1) change, or (2) exit without changing - choose (1) to change
5) Enter your fax number, then press <OK>
6) Enter your company name using the dial pad keys. This may take a little practice. Press the dial pad key the correct number of times to produce your desired letter. Use your (>) right navigation key to advance to the next space. If you entered a letter incorrectly and want to change it, press the left navigation key to move the cursor under the incorrect letter.
7) Press <OK> when finished
8) Press <Stop/Exit> to resume normal operation
There! You should have it. I hope this helps!
Brother MFC 240C Station ID
Mar 03, 2010 | Brother Multi-Function Center MFC-240C...
Brother 4100 fax m\c
http://www.brothersupport.com/Facsimile/User/um_zlefax.pdf
Setting Station ID
You should store your name or (company name) and fax number to be printed
on all fax pages you send. The telephone number you enter will be printed only
on your cover pages and call back messages. (See Composing Electronic Cover
Page
, Page 6-6.)
1 Press Menu, 1, 3.
digits), and then press Set. You must
enter a fax number to proceed.
3 Enter your telephone number (up) to
20 digits), and then press Set.
If your telephone number and fax
number again. The number appears
on Cover pages.
(up to 20 characters), and then press
Set.
(See Entering Text.)
5 Press Stop/Exit.
The LCD returns to the date and time.
If your Station ID has already been programmed, the LCD prompts “1” to make
a change, or “2” to exit without changing.
Aug 25, 2009 | Brother IntelliFax-2820 Laser Fax
Toshiba estudio16s need to change fax# inside machine
You have to change your OWN ID (fax) number through the menus.
Aug 03, 2009 | Office Equipment & Supplies
Our 2920 bother fax machine still has our old fax number on all printed paperwork. Could you please advise how we can change this to our current number? Thanks Lucy
You can change the Fax ID in the menu. It should be located in Menu/Set 0,3 (Station ID). Enter your new fax number, menu/set, new phone number, menu/set, your "name", menu/set. And you're set.
Jun 03, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
Brother all in one MFC
According to the user manual, which can be obtained at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
if you don't have one handy, the steps to set your fax machine's number is on page 42. The steps to take are:
Setting the Station ID
You should store your name or company name and fax number so
they print on all fax pages you send.
(up to 20 digits).
Press Menu/Set.
3 Use the dial pad to enter your name (up to 20 characters).
(See Entering Text on page B-11).
Press Menu/Set.
4 Press Stop/Exit.
You cannot enter a hyphen in the fax number. To enter a space
If the Station ID has already been programmed, the LCD will ask
you to press 1 to make a change or 2 to exit without changing.
May 15, 2008 | Brother MFC 420CN All-In-One InkJet...
every fax machine has a different proceedure so let me know what the make and model so i can help you
Mar 15, 2008 | Office Equipment & Supplies
Changing the text on my fax.
Lift up the cover under the display and press the data registration key, push "set" then scroll down using the arrow keys and look for "user setting" push set, and I think you scroll to the option that says terminal id push set enter your new name and push set again then you can enter your fax number. at any time push the stop key to exit out
Jun 14, 2007 | Canon FAX-L800 Plain Paper Laser
Fax number
Press fuction 7 1 key in date & time press set
May 22, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Brother MFC-5440CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
