Question about Health & Beauty
I have got an A.M.W. Explorer scooter. When I turn the ignition on the scooter will not go, either in reverse or forward. is there a way of releasing the brake, as the brake light on the dashboard is on
SOURCE: no life at all in classic 4wheeled mobility scooter
Have you checked your fuses with a continuity checker, they all my look OK, but Looks can fool you especially with the new type of two prong square colored fuses!
Posted on Nov 27, 2008
  • 7 Answers
SOURCE: After a period of use the Scooter turns itself off.
sounds like it might be a bad throttle pod, or the brake is overheating. If you can pull the rear shroud off and drive it for a while you can check to see if the brake is overheating. Be careful when checking it because if it is really hot it will burn your fingers. The throttle pod can be checked with an ohm meter but i'm not sure off the top of my head what reading you should get. let me know if you would go that far and i'll get it for you.
Posted on Mar 10, 2009
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
gewiz
  • 1263 Answers
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
Posted on Jun 14, 2009
FixinFax
  • 3085 Answers
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Posted on Jun 18, 2009
Hi I've got a rascal mobility scooter when u push the lever to go forward or back the reversing beeper come on and it doesn't move
could be low batteries or stuck relay or the lever that lets you push it is in released position .
Feb 29, 2016 | Health & Beauty
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
Why does my scooter stick in reverse & wont go forward
Your wigwag pot sounds faulty you can very often buy a good used one on eBay
Apr 24, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
Scooter won't reverse and makes clicking sound by the controller by the electric motor
There is a servo which switches the transmission from forward to reverse and it needs replaced.
murf427
Aug 01, 2012 | Electric Mobility Health & Beauty
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
No movement, forward or reverse
Apr 24, 2009 | Health & Beauty
Little gem mobility scooter brake not working properly
Oct 02, 2008 | Drive Medical Mini Phantom Three Wheel...
Health & Beauty Logo
101 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
