Manual 894 officeone 894
Where can I purchase a user manual for a gpx portable dvd player model pd951r?
You can download the manual for the PD-951R from the GPX product site: http://gpx.com/pd951r.html#product_tabs_downloads.tab . The direct link to the user's guide is: http://gpx.com/downloads/dl/file/id/894/pd951_ib.pdf . Since the file is a 2.4MB PDF, you can put it on any flash drive. Then you can have it printed at Kinko's or other copy/print location. I do not know of any sources where you can buy the printed manual without buying another portable DVD player.
I hope this helps.
Dec 19, 2015 | GPX Televison & Video
Krups superior
I have just bought a Krups Superiore 894 second hand but the instruction manuel is of no use as the pictures are not clear and when you put the coffee in it just goes straight into the discarded coffee grounds holder when you turn the drum. The discarded coffee grounds holder then fills with water. Have I bought a dud?
Oct 01, 2013 | Krups Superiore 894
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
The model number is Kenwood KA-894 integrated Amplifier I'm trying to find out how many watts. Thanks
The manual with 'specs' is here. Take them with a grain of salt because it's impossible to produce more audio watts than are consumed electrically (250 total).
http://www.retrevo.com/s/Kenwood-KA-894-Amps-review-manual/id/479ag211/t/1-2/
Dec 25, 2010 | Audio Players & Recorders
LOOKING FOR USER MANUAL FOR CDC ST630 TURNTABLE
I still use my CDC ST630. Using Nord replacement stylus Diamond 894.
Mar 30, 2009 | Audio Players & Recorders
Ram upgradation
The system uses shared video memory, so it will always show less memory than actually installed.
It's a good machine, but needs all memory it can get for Vista.
Good luck
Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Oct 30, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
23 people viewed this question
k24674
jasbo
jasbo
