Question about Dryers
Kenmore 90 series model 110 60902990 wont heat blows cold air
  • Mark Nichols May 11, 2010
    did you check and see if the heating element was getting electricity? simply check with voltmeter if not then change the safety on the left hand side of heating element channel... www.whirlpoolpartssurplus.com or call 866-798-4375
    President:
  • 1,136 Answers
There are a few things you can check. You will need a voltage/ ohms meter. First thing you should check is that you are getting 240 Volts too the dryer. If the dryer is getting voltage, then you will need to check the heating element first. Remove the lower front panel usually held on by 2 1/4" screws. The element is located on the right side of the dryer (Looking at the front). Unplug the dryer, check continuity on the 2 terminals on the element, if there is continuity, the element is ok. Next you will need to start checking the thermostats. There is one thermostat and one safety stat on the side of the element housing. Both of those should have continuity also. If all three os those parts are checking out ok, you wil need to check the safety attached to the blower duct work directly below the drum. The easiest way to get to that safety is to remove the lint screen duct.Two 1/4" screws hold that on.
These are the most probably causes of your dryer not heating. Please contact me if you need more info.
If this helps you and you need to order the defective part, let me know and I can ship you the part also.
Hope this helps.
Vic
Posted on May 08, 2009
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore 90 series model 110
If your dryer is running, but not heating the following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the section that discusses dryer ventilation. The number one cause of dryer failures is poor ventilation. Without proper air flow the dryer will overheat to the point of failure. Most commonly the Thermal Cut-Out fails.
Another source of this problem comes from improper input voltage at the wall recepatacle. The dryer drive motor only uses a portion of this voltage and runs off 110-120VAC, while the heating circuits require the full 220-240VAC. Some people have their dryer circuit on a double breaker. If yours is configured this way, double check to make sure one of the breakers is not tripped. This will give the same symptoms that you describe.
If you have any questions, please let me know. I hope this helps you solve your problem.
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
I have a kenmore 90 series dryer, it was working fine last night but this morning it was only blowing cold air. I checked the dryer vent and checked the heating element and there are no broken coils. What...
check the thermal fuse on the blower housing,if its ok then some units have a heater relay located behind the control panel thats controlled by the moisture sensor board its in the center of the panel but without a model number i cant be sure if this one has it
Jul 17, 2012 | Kenmore Dryers
My Kenmore 90 series won't heat up. Only blows cold air. Why?
could be a saftey or a bad heater in the dryer
Aug 27, 2010 | Kenmore Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
May 08, 2009 | Dryers
I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Mar 17, 2009 | Kenmore Dryers
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
545 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
