Maytag bravo washer not working sounds like loose change
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
  • 56 Answers
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
Posted on Feb 07, 2010
  • 572 Answers
SOURCE: maytag bravos washer that sounds like airplane
u need to replace the tub. includes the bearings
Posted on Feb 11, 2010
  • 4 Answers
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Posted on Aug 11, 2010
cyberprime1a
SOURCE: Maytag Bravos top load washer
Did you try readjusting the load, or maybe removing heavier items?
Posted on Dec 02, 2010
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Water leaking from the bottom of my maytag bravos washer
Depending upon the age of your washer, the pump may have begun leaking
Apr 21, 2013 | Maytag Bravos MTW6600T Top Load Washer
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
I have a 2 y/o Maytag Bravos MVWB700VQ0 top-loading washer that is suddenly making noise like there's either a) a chain loose in the drum of the machine, or b) a coin or other metal object is bouncing...
it is probably money in the pump. I have had my washer for two years now and an on the second pump. I had to call a serviceman to take the pump loose and dump out the change. It had 81 cents the first time and 26 cents the second. I need to call him again but I think I am going to try to do it myself. $85 a service call is just ridiculous when I know what the problem is.
Oct 12, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
We just bought a Maytag Bravos washer. We were
it should be very tight if you look down the middle of the adjitator it should have a aloy screw that should be done up very tight
Apr 24, 2010 | Maytag MAT13MN Top Load Washer
Maytag bravos washer that sounds like airplane
Feb 11, 2010 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
