Question about Frigidaire Washing Machines
Frigidaire flexcare cycle 9 will not drain or spin
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
  • 1531 Answers
SOURCE: my frigidaire GLTF2940ES washes but doesnt spin on
replace the door lock mechanism
Posted on Apr 10, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Jul 13, 2010
Frigidair flexcare top load washer. Is there a reset button or somthing els i could try ro get it to agitate and spin again?
Most common cause, if all else works Fill , Pump out ) is a loose or faulty door switch or one of its connections .
Apr 17, 2016 | Washing Machines
When the timer reaches the spin cycle the water does not drain or spin. All other functions are working.
Hello Joe, thank you for your inquiry!
From what you have described your Frigidaire washer will not drain or spin. I would recommend checking on the drain hose to make sure it is not restricted or too long. Also check to make sure your drain hose is not too far down your drain pipe. If the drain hose is in good condition it might be a possible problem with your timer or drain pump. Since it could any one of those underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. -Matt
Dec 11, 2015 | Frigidaire FWS933FS Top Loading 3.0 cu.ft....
I have a frigidaire flexcare washer fw233re and when i start the wash cycle the water drains out can you maybe tell me why
Check the drain hose, is it above the water level in the washer, if not it will always drain, there is no valve in the drain and gravity will win.
Dec 19, 2014 | Frigidaire Washing Machines
Washer wont spin
There are probably 12 causes for a washer not to spin,,,,I will
give you the least technical cause...the belt may be loose or
broken.
Regards,
Dennis
Aug 20, 2014 | Hotpoint HTWP1000MWW White, 3.4 cu. ft....
Why won't frigidaire fwtr445rfw clothes washer drain during spin cycle
Good Afternoon Friend,
I understand your Frigidaire washer, model# FWTR445RFW, is not draining during the spin cycle. First, please check the drain hose for any kinks or clogs. Next, check your home's drain pipe for any clogs. After you have checked the drain hose and drain pipe, I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Washing Machines
Frigidaire GLTF2940ES Washer. Clothes are soaking wet at end of cycle.
Suggestion:
WARNING: POWER OFF and UNPLUG WASHER. There are
intentionally ungrounded areas inside machine. Behind the kick panel at the bottom of the front (Two screws on the bottom front of the panel) you will find the Technical Data Sheet for the washer. Follow the instructions for running Diagnostics on page 2. When u get to step 9 the washer will test the spin cycle (give it a minute or so to start). That will at least see if your belt theory is correct. I am NOT a washer tech so I am only telling you what I have done with the same problem. I have not yet repaired it as this is a new problem, but the diags gave me an error code I am seeking info on now. Good luck!
Jun 25, 2012 | Frigidaire GLTF2940ES Front Load Washer
Describe your (ATF6000ES) Front Load Washer Problem it does not spin and its 9 years old
Hi twoofdkind,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Frigidaire front load washer not spinning
Unsrew the bottom panel and u will find the pump to the right disconnect the hose from the back thats coming down from the tub.You will find a pocket behind the hose connect filled with all kinds of change probably enough to buy a pizza and a couple of beers. I also had a old credit card,gas pass bobby pins,hard plastic tags.chains and a hand full of sand.
My Frigidaire frontloader is 9 yrs old was close to buying a new one but this defintly fixed the problem..
works like new again.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
