Question about Star Grilling
Have a gas grill(indoor resteraunt) that is not hot enough
The grill is 15" wide by 27" long, and is a table top of Star manufacturing.The grill has two burners and when on high does not produce enough heat to properly cook anything in a reasonable time
  • 81 Answers
Star is a comm'l manufacturer. If you are using it in a comm'l setting (ie. restaurant), then it may be set for the wrong gas type (it may be set for natural while you are providing propane). Is it lava rock or radiant? If your regulator is for the correct gas type and the broiler is for the correct gas type, call your gas servicman, he could, possibly, drill out the orifices, providing more gas to the burners, thus making them hotter (DO NOT TRY TO DO THIS YOURSELF!). The economy Star broilers have never been real hot (I am a comm'l restaurant equipment dealer) but your gas man could make it more acceptable. Call your professional, licensed gas serviceman to make things a bit better.
Posted on May 08, 2009
Recently replaced all 5 burner tubes and now when I light the grill it doesn't get hot enough - stays around 250 degrees.
Gerald, when you turned the gas tank valve back On, after replacing the burner, the OPD Valve in the grill tank partially locked up the grills gas regulator. To solve this problem, follow the steps below:
1. Turn the gas valve OFF and disconnect the hose from the tank. Wait 5 minutes.
2. Reconnect the hose to the tank and open the tank valve VERY, VERY, SLOWLY (Slow motion,
slow).
3. Once the valve is fully open, light the burner farthest from the grill first and turn it to HIGH. Does
the flame height look correct for the highest setting? If so, light the remaining burners the same
way. Now, to all the flame heights look normal for the highest setting. if so, you solved the
problem.
4. Close the hood/lid of the grill and allow it to preheat for at least 15 minutes. The temperature
reading (if your grill thermometer is correct) should between 400 & 450 degrees F, depending on
outside air temperature. Which is hot enough to sear a steak.
If none of the above corrected the problem. You will need to replace the grill's Hose/Regulator Assembly, because the regulator is partially locked up. You can pickup one at any home center or hardware store that sell gas grills and accessories for about $30.00. Take your old one with you for comparison purposes.
Hope this helped you to troubleshot and solve the problem. Happy Grilling!!
Jun 20, 2011 | Ducane 30400042 (LP)
Indoor grill won't light there is a spark and can smell gas. worked last night
clean area around where spark is hitting, check to make sure top is on perfect
Feb 04, 2010 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Replace indoor natural gas grill
Did you find a replacement? I'm looking for the same thing. I need a gas valve for mine and I can't seem to find it.
Jan 01, 2010 | Grilling
Gas grill caught fire
The anwer is not the one you want before Labor day cook-outs. Since the unit is under recall, go the manufacture's site, or any site specified in the recall notices, and follow the directions, to get replacement parts for all damaged parts from the fire, as well as the original defective parts. Hopefully you can take the unit in for exchange for a fully assembled one. Be polite but firm in wanting the units assembled gratis.
Aug 31, 2009 | Uniflame FG2204C Grill
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Jan 03, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Grilling Logo
106 people viewed this question
Top Star Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Star Grilling Expert? Answer questions, earn points and help others
