Question about Makita 14.4v 6337d 1/2" Clutched Drill/driver
Keyless chuck on Makita 6337D does not tighten fully. Bit slips. Suggestions?
Can the Chuck be fixed so it tightens fully? Can it be replaced?
SOURCE: Chuck won't tighten
The chuck is held onto the drive shaft via screw located inside the chuck. The screw has reverse threads and sometimes the screw gets loose restrictinhg the chuck tightening. Turn the chuck to loosen and tighten the screw as though you were removing a normal screw. Good luck
Posted on May 23, 2008
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 44 Answers
SOURCE: remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Posted on Oct 23, 2009
How do I remove a stuck drill bit from a Makita keyless chuck accessory?
If the drill bit is stuck where it was inserted before tightening and, even if it broke off, put the chuck in a vice with some kind of cushioning to protect it from scratching, soak the whole assembly with wd 40 or similar, and, assuming that you can get a wrench, with some cushioning, on the part that holds the bit, see if you can't turn it. Some tools have tighteners which are made to turn opposite to what you might think so try it both ways.
Mar 15, 2014 | Drills
The chuck on my Craftsman C3 drill won't stay tight
If you have a keyed chuck then yes as the jaws are not parallel any more from wear. If keyless then the thread inside the chuck cover is damaged and not tightening properly. So again yes a new chuck will be the answer.
Jul 29, 2013 | Craftsman Drills
How do I remove the drill bit from a Makita6223D?
If your drill has the original keyless chuck on it, there are two plastic rings on the chuck. The outer ring should tighten and loosen by hand enough to hold the bit(s). The inner ring is to hold on to if the chuck gets overtightened. Chucks do wear and get corroded over time and can get locked in position. If you can't get it loose by hand, channel lock pliers can help. If the chuck is that bad you may need to replace it.
Mar 03, 2013 | Makita 9.6v Cordless Impact Driver 6903VD
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
I have a rotozip 20 and the new keyless chuck just does not work. Am I doung something wrong?
Try not inserting the bit all the way in until it bottoms- it should not bottom. Also make sure it is the correct size range for the bits you have.
Feb 10, 2012 | Bosch Drills
How to fix the bit
If your Makita matches the one on the picture, you will need a chuck key to attach a drill bit or tool to the machine's chuck. The chuck key inserts to any of the small holes in the front part of the chuck and at the same time its teeth interlocks with the teeth of the chuck. When turning the chuck key you will widen or loosen the grip of the three jaw pieces, that clamps to your tool or bit. Tighten the chuck key by hand until the chuck grips the bit securely. For safety, unplug the power cord whenever operating the chuck key on the chuck.
Jan 09, 2011 | Makita & 1/2 Inch Drill
How to tighten drill bit on makita 6343d
your must have a keyless chuck. hold the black center part of the chuck and run the drill forward or backward to open or close the chuck.
Jan 26, 2010 | Drills
May 04, 2009 | Makita Drills
Makita 6405 3/8
according to my breakdown its a drill. do you checked if there is a screw inside the chuck. if there is one remove it by turning clockwise.open the chuck fully & insert allen key 5/16 or 3/8 short side to the chuck.tighten the chuck & wak the allen key with a hammer counter clockwise. do it again if required.putting back together the other way.
Jun 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 6337D cordless drill problem
It is possible that the batteries are no longer good. They may need to be changed. These batteries do reach a stage where they no longer hold charge.
On rare occasions I have seen the gear box jam or the motor bearings go defective.
Jerry G.
Apr 01, 2008 | Kitchen Appliances - Others
Makita 14.4v 6337d 1/2" Clutched Drill/driver Logo
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
