Question about Kliik Health & Beauty
Nose piece broke - Kliik Health & Beauty
Led bulb 194 broke off in socket of 2008 Chevy hhr side marker how can I remove it?
disconnect the socket electrically, then use needle nose pliers or a sharp pick to pry the piece out.. then put the socket back in and then hook it up electrically.. and install a new bulb...
Sep 17, 2017 | Cars & Trucks
2002 Jeep liberty handle on glove compartment broke how do I open it
If the handle broke off completely, then you should be able to see what the handle pushed on or pulled on to open it, then you might be able to push on the latch mechanism with a screwdriver or pull what's left of the handle piece with a pair of needle nose pliers
Dec 27, 2016 | Jeep Liberty Cars & Trucks
I have 2002 jeep grand Cherokee limited v8 I was changing the crank position sensor and it broke off can't get rest out any ideas to get it out
I can only give you suggestions since I don't see what you see. Since it broke off possibly you can grab what's left with a pair of needle nose pliers or needle nose vise grips. If this doesn't work try drilling a hole thru the center of what's left. Do this very gently since you don't want the piece to fall thru the other way. You may be able to put a piece of wire thru this hole that you would make a hook on the end ( clothes hanger wire ) , and use the hook to grab from behind, and pull out. Now the worst scenario would be the piece falling in the other way, if this happens most likely it will fall into the oil pan and eventually wash down into the oil pan. If the piece is at the flywheel end of engine it will fall to the bottom of bell housing. You will have to accept what happens, unless you want to drop oil pan or part engine and trans to pull out piece. GOOD LUCK FRIEND.
Nov 22, 2014 | 2002 Jeep Grand Cherokee
1999 Nissan Maxima, key broken off in ignition, any ideas?
Use a small or mini pair of needle nose pliers to grab it and pull it out but make sure it is in the off position
Jun 21, 2014 | 1998 Nissan Maxima
Cant pull 140 alt fuse rx 330
No it isn't bolted in. Disconnect battery and then use needle nose pliers to pull the pins.
Feb 16, 2012 | Lexus RX 330 Cars & Trucks
'88 Samuria.....OK....got the shifter out, but can only see tiny pieces of what probably WAS the bolt end. What do I do now?
Remove the lower four bolts (hope you did not lose any broken pieces into the trans.) and holding the part in a vice, remove the broken bolt and the nose piece that broke off. You may have to use a little extra force to get the new special bolt all the way in due to some damaged threads; put some sealer on the gasket and refit
Nov 17, 2010 | 1988 Suzuki Samurai
Key broke off in lock on trunk door. How do I get
Sometimes a small needle nose pliers can grasp
the broken key.
A hard ware store can help in the getting of the pliers.
Good Luck!!!!!!!!!!!!!!!!!!!!
Jul 02, 2010 | 1990 Mercury Grand Marquis
Broke little piece coming from itnitor, still has half of tip
Hello. If you still have the piece you may be able to permanently reattach it with some clear epoxy adhesive. I like the one minute clear epoxy which does not require clamping.
IF your piece is not glueable then I recommend that you order a new part. One good source is http://www.lewiscontractorsales.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=keroseneheaterparts
Regards, Joe
PS please rate my answer. thank you.
Jan 06, 2010 | All-Pro Forced Air Kerosene Space Heater...
Health & Beauty Logo
18 people viewed this question
Top Kliik Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Kliik Health and Beauty Expert? Answer questions, earn points and help others
