Question about Conair DCC-3000 - Cuisinart Coffee on Demand DCC-3000 Brewer
Doesn't empty water from reservoir during brewing cycle
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Tip
Keurig Home Brewer instructions for de-scaling with white Vinegar
A. PREPARE
Step 1. Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug ( do not use a paer cup).
Step 2. Empty the water in the water Reservoir.
B. FILL AND CLEAN
Step 1. Pour the vinegar into the water reservoir and fill it to the top edge of clear viewing area.
Step 2. Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-KUP … just press the Large Cup Button. Pour the contents of the cup into sink.
Step 3. Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4. Now fill reservoir with fresh water and let the brewer stand for 4 hours while still on.
C. RINCE
Step 1. Ensure the Water reservoir is filled with fresh water.
Step 2. Place a ceramic cup on the drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3. Repeat the brew process until the Water Reservoir is empty.
Step 4. You may need to perform additional brew cycles if you notice any residual taste.
on Aug 10, 2010 | Coffee Makers & Espresso Machines
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Did not make the large cup of coffee. Then we de-scaled the machine with vinegar. The computer seems off. The hot water is coming back into the water reservoir.
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Nov 21, 2010 | Keurig B50 Coffee Maker
What is de-scale?
Descaling removes the deposits left behind from hard water. These mineral deposits will slow heat transfer if not removed from the heating element. To descale the coffee maker, use 48 oz of undiluted vinegar (household strength) and have a large ceramic mug to hold the output. Empty any water in the reservoir. Pour vinegar into the Water Reservoir and fill to the top of edge of the clear viewing area. Place a mug in the drip tray and press the Large Cup Button. (Do not use a K-cup.) When the brew cycle finishes, pour the contents of the mug into the sink.
Repeat the brew cycle until the reservoir is empty. Open and close the lid between cycles. When the reservoir empty, fill with water and let the coffee maker stand for 4 hours with the unit ON. After four hours, rinse the coffee maker by doing several brewing cycles (again without a K-cup). Discard the liquid after each brew cycle and repeat until the reservoir is empty.
You may need to perform additional brew cycles if you notice a residual taste.
For more information, including a pdf with the directions for descaling of the coffee maker, see http://www.keurig.com/customer-service/brewer-registration-and-support/frequently-asked-questions .
I hope this helps.
Oct 21, 2010 | Keurig B50 Coffee Maker
Keurig b30 won't brew
Jan 08, 2010 | Keurig B100 Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
My keurig wont brew
Sep 03, 2009 | Keurig B60 Coffee Maker
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Conair DCC-3000 - Cuisinart Coffee on Demand DCC-3000 Brewer Logo
Top Conair Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Conair Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
