Question about Winegard Gm 1518 Carryout (tm) Automatic Portable Satellite Tv Antenna
Gm-1518 to 211z
Doing initial setup of a new gm-1518 antenna to new Dish 211z receiver. Receiver isn't seeing the antenna nor identifying the switch (should be SW64). Tried the switch test and it fails. Talked to Dish tech support and they don't have a solution either. Anyone have similar problem and found a solution?
2 Suggested Answers
SOURCE: My gm-1518 sounds like it
This problem is a software glitch affecting 301, 311 receivers and the 5xx series DVRs. Even though the manual says not to, the solution is to select "Superdish" and "Alternate Dish" before doing a check switch.
Posted on May 02, 2012
Why does my dish network say it has been diconnected and do i fix it
There are many reasons it would say this, all of them based on how DISH recognized the combination of your SMART card and receiver number. DISH authorizes the correct combination of your SMART card and receiver so that you cannot just have one or the other and have it work. They may have intentionally disabled your account for non-payment or some other customer service related issue. Your SMART card may be damaged (if removed the screen would read "Please Insert Your Smart Card"). You should contact customer service
If the message on the screen reads, "A cable has been disconnected" it usually means that in the process of trying to find a signal, it could not. The cable between the receiver and the antenna (aka the dish) may have been damaged or cut. The antenna may have been damaged or installed incorrectly. This message is usually only shown when installing a new receiver. If you had an issue and they sent you a replacement receiver, this is more than likely the problem. Make sure that the cable coming from the antenna (usually from the wall or the floor) is plugged into the receivers satellite in, or the triplexer (a silver rectangle with three cables coming out to the receiver) 's in. If the cable is in the right spot (the triplexer's cables that go to the receiver are color coded and marked) and you still have the issue after unplugging and then plugging back in the receiver, the problem was not the initial receiver, and was instead either the continuity of the line to the antenna or the antenna's installation. (Poor or non-existent antenna reception means it was installed wrong or damaged). You would need a technician to solve these problems without more experience yourself.
Dec 27, 2014 | DISH Network DVR-625 DTV Receiver /...
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
May 08, 2014 | Televison & Video
Will a 7yr old dish receiver work today on dish satillite
With an antenna that is pointed correctly to satellites 110 and 119, the receiver will function, but will not have access to paid channels without authorization from DISH (which you can get by calling 1-800-333-3474). You may have to run a check switch test after connecting to antenna by accessing the menu, system set-up, installation, check switch.
Jan 27, 2013 | DISH Network 311 DTV Receiver
Is there a cord that connects my tv to my dish box? It is a VIP 211k.
Ethan Lensch,
I can definitely provide more assistance with this. The TV doesn't connect to the dish itself. The cable from the dish goes into a switch, then from the switch it runs in to your receiver.
On the back of the receiver is a "SAT IN" slot. Verify the cable plugged in there is hand tight, and follow it back making sure any other connections you see are tight. If the signal doesn't return, unplug the receiver for 10 seconds and plug it back in.
If the signal is still out when it powers back on, run a check switch test. This is done by going to Menu > System Setup > Installation > Point Dish > Check Switch > Test. When it is done it will either go back to the Check Switch screen, or give you a message. If it takes you back to the screen, exit out and see if signal returned.
If the signal still isn't returning, or you get a message saying "Fewer satellites dectected", let me know here or by email at thomas.faust@dish.com and I can look into getting a tech out to fix this!
Tommy Faust
DISH Social Media Representative
Nov 11, 2012 | DISH Network ViP 211K
My gm-1518 sounds like it is lining up on a satellite, but my receiver shows no satellites picked up. It has worked perfectly the last time I used it (July 4th week). Do you have any solutions to this...
Aug 30, 2011 | Winegard Gm 1518 Carryout (tm) Automatic...
Umm my tv2 remote isn't connecting to my reciever so i tried to change the remote address and it doesn't work
Hi my nameis Mike Houston of DISH Network and I see your TV2 remote isn't connecting toyour receiver. You will want to make sure you're at the TV1 location to programthe remote for TV2, press the Menu button 2 times and you will see the SystemInfo screen. On the bottom for the screen you will see the remote address forTV2, make sure the TV2 remote has fresh batteries inside. On the back of thereceiver their will be a Remote Antenna port and you want to make sure that ishand tight. Push and release the SAT button and press record and you should seethe address change for TV2. I will send a link to help with these steps; http://www.dishnetwork.com/SupportSection/remote-control.
Jul 30, 2011 | DISH Network 322 DTV Receiver
The channel guide only shows no information available most of the time
sidbashford
You are getting that message because the receiver is not updating the Electronic Program Guide (EPG). Try unplugging the receiver from your electrical outlet for about 10 seconds (make sure all lights on receiver go out) and plug back in. This will cause the receiver to reboot and re-acquire satellite signal. Allow it also to download the program guide. After you get your channel back, pull up your guide, go into the future to see if it updated.
If it did not update, you'll need to run a check switch test. Press Menu on your DISH remote; should have Main Menu on TV screen. Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get to Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 26, 2011 | Televison & Video
Initial gm-510 gps has intermittent gps signal and loose antenna
well a loose antenna can cause intermittent connections, but so can a low battery, despite it being plugged into a power source. Make sure battery is fully chatrged before use. I would suspect the battery chage first. Even get a new battery
Jun 30, 2009 | Initial Global Navigation GM-510 GPS...
Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Winegard Gm 1518 Carryout (tm) Automatic Portable Satellite Tv Antenna Logo
52 people viewed this question
Top Winegard Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Winegard Boating Expert? Answer questions, earn points and help others
