Question about Staples SPL1524CP Strip-Cut Shredder
Shredder not working
Shredder stopped working after being used for more than 2 hours a day. Checked power to shredder, the power is good, bypassed small switch inside of the shredder and it came on . I need to replace the switch.
3 Suggested Answers
SOURCE: I need to replace the plastic guides in a Staples
did you ever figure out where to get these guides? i need them too. jeff
Posted on Nov 16, 2010
  • 300 Answers
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Posted on Feb 14, 2011
My shredder will not shredd paper
1. There is usually a small metal piece in the basket portion that has to hit the shredder when in place. If it gets bent, it won't line up and wont work. You can easily bend it to fit if that's the problem.
2. In general most people (like me) get all excited the first day of a new shredder. It will automatically STOP when it over heats. Don't worry, just wait until it cools itself long enough, turn it back on and it works again.
3. Aluminum in a shredder??? Never heard of that. sorry.
Sep 18, 2014 | Shredder Secure Shred Shredder
My shredder stoped working
My shredder was under warranty--not officemax warranty--so I sent it back to the company that manufactured the shredder, at my expense. They sent me a new one at their expense. Had I added a few more dollars to the shipping for a new shredder. I never could get my to accept paper or lubricating sheet. Did not open the exchanged shredder until 2 days ago and so far it works, however the original one worked for about a week before stopping. I believe--should I have the need I will purchase a different brand.
I hope that helps.
Apr 11, 2014 | OfficeMax 10-Sheet Micro-Cut Shredder...
My shredder won't power on. It is not overheated.
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Aug 11, 2013 | Staples Cross-Cut Shredders; 10 Sheet
Shredder stoppped working, no display or power when restarted. Power cable is good.
Aug 07, 2013 | Universal Office Equipment & Supplies
Doesn't work in auto position but works in reverse
Most likely your optic sensor has something in front of it. Clean out the unit really well. It does take time, about 3 different screwdrivers, lon pliers and tweezers and a vacuum or compressed air. After that, learning more new words and swearing to god you will never let this happen again until the third time.
Jan 06, 2013 | Black & Decker BD10P Shredder
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
    Instructions
    Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
    Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
    Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
    Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
    Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
    Good Luck!
    Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
    GBC Shredmaster 3220S stopped taking paper in and makes a loud,
    Myi shredder does the same thing so I removed the screws to see what was going on inside.
    What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
    May 21, 2010 | Quartet gbc 2230S Shredder
    The overloa light comes on and the shredder stops immediately. the hopper is empty and there doesn't appear to be anything blocking the shredder. i was shredding for about 1/2 hour when this started. i've...
    You have probably "fried" the pcb inside the machine.....this is a "consumer" machine...no more than 5 mins ON then 10 Mins OFF to let it cool down.....you should only shred about 70% of the MAX rating for the machine.
    For Parts advice call Royal at 1-800-524-0799.
    Feb 13, 2010 | Royal VF1012mx Shredder
    Shredder no longer runs
    Fellowes Customer Service is the best in the business call them at 1-800-945-4545
    Dec 06, 2007 | Fellowes P600C-2 Shredder
    Staples SPL1524CP Strip-Cut Shredder Logo
    60 people viewed this question
    Top Staples Office Equipment & Supplies Experts
    Saleem Baig
    Saleem Baig
    Randy Schumann
    Randy Schumann
    Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
