Victualing formula - Computers & Internet
Hi, My formula will not give me the correct sum when I drag it down into new columns even though the formula is correct. Please advise
What happens if you copy the formula from one cell and paste it into another? Sometimes formulas don't drag correctly. This can happen especially when you have more complex formulas. Another thing that can throw off the drag and drop copying of formulas are hidden rows or columns.
If a copy paste doesn't fix the issue than reply with the exact formula and a snippet of your data so I can troubleshoot it better.
Apr 04, 2017 | The Computers & Internet
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Wat is special product
Here, We deal with Some Special Products in Polynomials.
Certain products of Polynomials occur more often
in Algebra. They are to be considered specially.
These are to be remembered as Formulas in Algebra.
Remembering these formulas in Algebra is as important
as remembering multiplication tables in Arithmetic.
We give a list of these Formulas and Apply
them to solve a Number of problems.
We give Links to other Formulas in Algebra.
Here is the list of Formulas in
Polynomials which are very useful in Algebra.
Formulas in Polynomials :
Algebra Formula 1 in Polynomials:
Square of Sum of Two Terms:
(a + b)2 = a2 + 2ab + b2
Algebra Formula 2 in Polynomials:
Square of Difference of Two Terms:
(a - b)2 = a2 - 2ab + b2
Algebra Formula 3 in Polynomials:
Product of Sum and Difference of Two Terms:
(a + b)(a - b) = a2 - b2
Algebra Formula 4 in Polynomials:
Product giving Sum of Two Cubes:
(a + b)(a2 - ab + b2) = a3 + b3
Algebra Formula 5 in Polynomials:
Cube of Difference of Two Terms:
(a - b)3 = a3 - 3a2b + 3ab2 - b3 = a3 - 3ab(a - b) - b3
Algebra Formula 8 in Polynomials:
Each of the letters in fact represent a TERM.
e.g. The above Formula 1 can be stated as
(First term + Second term)2
= (First term)2 + 2(First term)(Second term) + (Second term)2
Jul 02, 2011 | Computers & Internet
Why don't formulas copy from cell to cell?
Step 1
Determine what formula is to be copied and to what location it is to be copied. Carefully consider the cells that are to be referenced in the formula and that they are indeed the cells that contain the information to be acted upon by this formula.
Step 2
Highlight a cell that has the formula in it and click the right mouse button. Select the "Copy" option.
Step 3
Move to the new destination cell for this formula, right click the mouse button and select "Paste."
Step 4
Check the first cell to make sure the correct calculation has been performed. If not, check the formula that appears in the cell that contains the result of the formula that was just copied. Make sure that the formula references the correct cells. If not, correct the formula and then copy the corrected formula to the rest of the cells that should have this formula applied to them.
The only time I have seen this not work is when the cells/pages are protected.
Note:
Some formulas will require references to multiple pages or a workbook. Make sure that the absolute cell address is used for specific numbers and those that are to be applied to subsequent cell addresses are clearly denoted by the use of "$" in the cell address.
Dec 17, 2009 | Microsoft Office Home and Student 2007...
I need Excel's Furmula's
I found some excellent links to excel formulas for you:
This link lists excel formulas by category:
http://www.techonthenet.com/excel/formulas/
This link has some custom formulas for excel that you can download:
http://www.ozgrid.com/VBA/Functions.htm
Sep 20, 2008 | Microsoft Computers & Internet
Excel formula
Relative cell reference is address of cell , when copied from one cell to another gets changed automatically.
e.g. Put formula in cell c5 as A5+1 when you copy this from c5 to c6 the address of A5 will automatically changed to A6.
Absolute Cell Reference
As above now put formula in cell C5 as $A$5+1 ,now copy this formula from C5 to C6 if you this formula youwill find cell Address of A5 does not changed.
Mixed Cell Reference:
If we put Dollar ($) sign before Alphabetic cell address i.e.$c5 then even if you copy this formula in any cell , coloumn (c)  will remains constant.
Similarly if we put Dollar ($) sign before Numeric cell address i.e.c$5  then you copy this formula in any cell row address of the cell remains same.(5).
Pl elobarate on remaining two points 'Specific order of formulas ' and 'advance formulas,
Sep 15, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
