Question about Optics
Windage adjustment I have a hertel&reuss Kassel macco -ziel 4x36-l81 scope and am not sure how the adjustments work to adjust the elevation
SOURCE: zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Posted on Jan 25, 2009
  • 3 Answers
SOURCE: windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
Posted on May 04, 2009
  • 6982 Answers
SOURCE: New Zeiss 2.5-8 Conquest MC Riflescope. Elevation clickstop adjus
Tried google for zeiss rifle scopes I just did and see they have a suport division...try there and get it from the horsies mouth!!!
Posted on Jun 19, 2009
  • 30 Answers
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Posted on Sep 01, 2009
Adrian762
  • 425 Answers
SOURCE: I have lost the covers to my windage and elevation
From any reputable gun shop that stocks simmons scopes.
Posted on Feb 14, 2010
How to use redfieeld 3x9x42 scope
Depends on the scope and rifle type to which it is attached.
I invested in an inexpensive laser bore such as this one for an AR: SightMark AccuDot Laser Bore Sight - 223 Model SM39001 (for AR-15)
Once the scope is mounted properly, and assuming you have not made any vertical or horizontal adjustments, set the rifle on a stable platform, insert the bore sight, point it at a target 50 (rimfire) to 100 (AR) yards out (works best in low light situation).
Once you have the laser centered on your target, make elevation and windage adjustments as necessary placing the scope cross hairs over the laser. Remove the bore sight and fire 3 rounds, then fine tune elevation and windage.
Dec 27, 2014 | Optics
How to reset bushnell elevation adjustment to zero?
If you want to center the cross hair in the scope
Rotate elevation down to it stops then count up clicks to it stops then half number and rotate down that number then repeat with windage or you could use two v blocks and view a point through the scope and rotate scope and adjust cross hair until no deviation from a fixed point up or down left or right
Hope this helps
Dec 07, 2014 | Bushnell Optics
Cannot set wind age and elevation on a Nikon pro staff riflescope (not enough adjustment )
Check you mounts. If mounted properly you should have enough. if they are not moving at all you have prob broken the fine wires that form the crosshairs.
Jan 07, 2013 | Nikon 3-9x50 Prostaff Riflescope In Matte...
How to disassemble my bushnell sportsman rifle scopes coz i wnt to clean it
On my Bushnell scope I have an adjustable angle ring that will bring in the view, it is held in place with 1 screw. remove it and pull down towards the windage and elevation adjustment screws. There are 3 tiny phillips screws, remove them. Then unscrew the end of the Eye Peice end peice with the lens in it. inside on the outer edge of the main tube there is a locking ring that keeps the eye peice from unscrewing off, remove it and unscrew the entire eye peice. you are now ready remove the inner tube. Be careful here this is where you can damage the cross hairs and lose the leaf spring that maintains pressure against the windage and elevation screws. When you reassemble after cleaning and with the elevation screw at 12 o'clock and windage screw at 3 o;colck, the leaf spring will be in the 7 or 8 O"clock position, it just sits in there up against a little ridge inside, with the bow facing to the center. Back off the elevation and windage screws all the way so they don't block the inner tube from going in all the way. Once it is in adjust it so the cross hairs are orented correctly and put it back together. If you want to refill with Nitrogen remove the front lense and take to someone that fills tires with Nitrogen and inject the nitrogen into the scope, Quickly reinstall the front lens as nitrogen is about 3% lighter than air and if you take too long it will all escape.
This worked well for me. Good Luck and Happy shooting
Apr 27, 2011 | Bushnell Sportsman 4x32 Riflescope (4x32...
Jun 07, 2009 | Conquest Zeiss 3.5-10x50 Mc Rifle Scope :...
Windage and elevation adjustment all over the place
May 02, 2009 | Optics
Windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Apr 07, 2009 | Optics
Zeroing scope adjustment
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Lost manual for trophy scope 3-9x40 rifle
There is no manual for elevation and windage adjustments. (at least not one that comes with your scope; all your scopes manual will say is whether its FFP or SFP (First Focal Plane or Second Focal Plane, the scale used on your scope for mil dots)(you can get this info by finding a store that sells this scope and asking a sales rep)
To adjust for elevation and windage you have to take into account the daily factors (unless your shooting in the same indoor environmental controlled shooting range each day you SNOB! jk
The formula takes alot of variables into account and is known as Exterior Ballistics
!) Environmental Factors - First thing you account for.
A) Elevation from sea level plays a large part into your environmental adjustments. Your elevation from sea level determines largely the Barometirc Pressure but it also varies slightly with Temp and Humidity (Major Factor)
B) Temperature - The temperature can affect the density of the air. The hotter it is the thinner it is and therefore less resistance and a higher bullet trajectory (Minor Factor)
C) Humidity - This again will affect the densify of the air infront of your bullet (Minor Factor)
D) Barometric Pressure - The other large factor in air density this is the base stat that the others modify
These all combined create a ratio that you apply to standard MOA (windage and elevation adjustments) to obtain the shooting information for that particular environment)
2) Bullet Factors (Listed on the Box you buy) - There are a few bullet factors to take into account.
A) Speed - the bullets feet per second can vary as much or more than 500 feet per second with the
same caliber ammunition.
B) Grain - The Grain of an ammunition is a measure fo its "Sectional Density" or weight to volume
ratio
C) Ballistic Co Efficient - This number is the measure of the bullets ability to maintain its speed
during flight. This also varies from Grain to Grain
These factors are complex and a pain for the best of shooters to determine. adding to that confusion. there are many ways to determine a bullets ballistics coefficient and each one gets a different number. In this case bullet data is best retieved from the manufactuerers box and take their word for it.
3) Lastly you account for shot factors.
A) Range - by referencing your standard elevation MOA adjustments and mutliplying by the ratio for environment the Elevation MOA is achieved.
B) Windage - Windage is done in inches per mile per hour then is multiplied by the Mph of the wind.
In order to be precise the windage is done in inches instead of MOA. it needs to be converted heres and example.
You Ballistics Cheat Sheet for the day says the windage at 900 yards is 5.2 Inches per mph of wind.
you apply the ratio for your environment .90 (all example numbers. this number would represent a shooting environment with an air density lower than standard/ the cheat sheet's known MOA adjustments). the 5.2 inches is multiplied by .9to acheive 4.68?? idk the point is you mulitply that by the wind of 10 mph to achieve a total of 46.8" of wind drift to the target.
now for the conversion to MOA. 1 MOA is eqaul to 1.047" per 100 yards. meaning for every 1 moa you adjust the bullet will move 1.047" per 100 yards (our target is 900 yards; meaning that each MOA for this target is 9*1.047" = 9.423" per MOA adjustment. so take that number and divide our total wind drift by it. ie 46.8 / 9.423 = MOA Windage Change of 4.9665... now you need to know whethere your scope is 1/4 minute clicks or 1/8 minutes (how many spaces between large numbers?) you would adjust to 5 MOA for a 1/4 minutes scope equaling 20 clicks on an 1/8th minute scope it would be 40 clicks.
This is the math of shooting. to learn how go to
WWW.shooterready.com they are an excellent sight to get the math down WITHOUT wasting ammo. Once you have the math you an transfer it to your gun. waste a few rounds checking it out and youll be hitting targets @ 1800 yards in no time
I like to take the simple way after i learned how to do the hard way
There is software tha will do the exterior calcualtions for you.
if your interested i use Sierra Infinity V6 Ballistics Software
GL
Dec 08, 2008 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Lost caps
I'm not sure how this got posted in the car audio section...
If the scope was manufactured by a well established company, you should be able to get a new cap from them.
If you cannot locate the manufacturer, you can move the other cap to the windage adjustment to set the windage. Then when you're finished, move the cap back to the elevation adjustment.
Even if you use it for a shooting discipline that requires constant adjustment, it's unlikely that you'll need to use the windage adjustment for anything other than setting the zero.
Oct 16, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Optics Logo
26 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
