Question about LG Dryers
Lg dryer keeps saying add water - LG Dryers
What does it mean when my LG true steam dryer has and indicator on that says flow sensor
That might have something to do with the exhaust vent in back of the machine. It could be that it isn't venting properly. Or the other thing it could be is that where the cold water hose is connected to the dryer for the steam could be kinked therefore not allowing sufficient water flow.
Dec 01, 2015 | LG Dryers
LG Electric Dryer DLE2140W, it keeps running plus no heat. It says check filter, but filter is all clear.
Dryer will only turn off when cloths are dry. Seems like you have a failed heat circuit. If electric, first reset the circuit breaker (double) a couple of times. If gas, call a tech.
Oct 14, 2015 | LG DLE2140W Dryer
Lg front loading dryer keeps saying check filter. The filter is clear. Should I reset? If so how do I do this?
clean all the way through the dryer to the outside,there is a blockage,it can cause problems
Jul 11, 2015 | LG Dryers
Do not buy an LG Tromm front loader unless you want stinky, moldy clothes! The first few months, I LOVED this washer, but now I think the machine is possessed by smell demons! I've tried everything, but...
Stinky clothes are usually the result of washing in cold water. Cold water will NOT kill bacteria.
Add one cup of vinegar to the wash before you start the machine - try it.
The vinegar will kill the bacteria during the wash. Your wash will NOT smell of vinegar.
The dryer level of dryness on most auto dryers needs to be set three clicks toward + on most machines. LG is no different.
Apr 02, 2010 | LG WM1812C Front Load Washer
The dryer keeps shuting off and saying check filter
Check the rear exhaust vent at the bottom back of the dryer. If it is clogged it can cause the dryer to "overheat", that is ... if the vent is clogged with lint and debris a fire could start if there was enough heat.
Please rate this answer for me. Thank you
Mar 26, 2010 | LG DLE5977 Electric Dryer
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Dryers Logo
327 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
