Question about Saeco Syntia Espresso Machine & Coffee Maker
Hi, my saeco syntia has a spanner display on
After I turn it ON, it's rising than a spanner display. But can not any coffee.
  • 70 Answers
SOURCE: saeco magic comfort coffee machine
sounds like the thermal resistor may be going bad.
Only way to get this fixed is having it sent out to a service center. Machine needs to be opened up and the resistor and a few sensor's need to be checked.
Posted on May 14, 2008
  • 40 Answers
SOURCE: Saeco Incanto Classic Espresso Machine Saeco
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
  • 41 Answers
SOURCE: my saeco magic deluxe, doesn't make coffee all the time
Sounds like early stage of stripped gears in Gear assembly or faulty Main electronic board. These are the 2 most common problems.
Posted on Apr 04, 2010
SOURCE: saeco syntia - error message 'problems with the
I read your post. Could you explain me this problem?
Me too have a syntia, but I never saw this error message.
What kind of symbol do you see?
bye
F
Posted on Jul 12, 2010
dcramer531
  • 1654 Answers
SOURCE: I have a sauce syntia
The red icon on front is the call for water, is your machine full? If so the majority of the times it is do to a clogged filter (usually a small metal perforated disk) Check to assure it is fully cleaned, for very difficult clogs soak or you can use a safety pin to clear the more difficult holes. It could also be a scale build up issues so you can perform de-scaling of the machine two - three times one every day and
try to draw out the dissolve water and de-scaling solution in steps with 5 -10
minutes interval. This will give more time to the solution to dissolve the sale
build up in your machine. You can also try a reset. remove the water tank.
Remove power plug and keep aside, Now attach the tank back and test after 1 hour so that it is reset. If this does not clear your Icon after making sure the water tank is full. Then a service call will need to be done as there is some issue with either a sensor or possibly the boiler which has to be perfomed by a trained technician. You can find manual and part6s here for the machine
http://www.partsguru.com/SaecoRioProfi.html
Posted on Apr 08, 2011
I have a Saeco syntia which I usually add beans, but have ground coffee and am not sure how much to add
If it's an espresso machine, you can find a manual at link. Use the scoop provided with the machine and add 1 scoop, no more than 2 scoops.
Visit the support page for your Saeco Syntia Super automatic espresso...
Oct 07, 2017 | Saeco Coffee Makers & Espresso Machines
My coffee machine wont't turn on
Check the fuse in its plug for starters.
May 02, 2017 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Syntia and a Red Wrench with the #14 came on the display. I have turned on and off and now the yellow thermostat symbol comes up. you can feel it heating up but it does nothing else.
need to tell me when the wrench appears ,at start up ? YES? then most likely "over pressure valve" is broken and machine needs to be serviced by service center to replace the plastic part with a metal parts ,Stop using it or the leaking water will damage the system .
Jan 18, 2014 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia leaking out the bottom
Over pressure valve is broken, near the water pump , stop using it and get it fixed , or you may damage your Computer board
Nov 08, 2013 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia ground coffee chute not working well
The grind on the coffee might be too coarse and instead of making espresso its coming out like drip coffee because the water is running through it too fast.
May 25, 2012 | Saeco Syntia SS Automatic Espresso Machine
Water tank parts for saeco syntia
Don't know where you are but www.dutchwest.co.uk in the UK supply the parts.
Mar 02, 2011 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia - error message 'problems with the water circuit'
bye
F
Jul 11, 2010 | Saeco Coffee Makers & Espresso Machines
Saeco Syntia Espresso Machine & Coffee Maker Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
