I have a hotsy 965ss pressure washer and the burner won't stay lit
It lites when I squeeze the trigger and then goes out
SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Posted on Jul 18, 2008
godtech
  • 51 Answers
SOURCE: the heater won't stay lit
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
Posted on Jan 16, 2009
  • 139 Answers
SOURCE: Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Posted on Jun 21, 2009
  • 75 Answers
SOURCE: pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Posted on Nov 08, 2009
  • 33 Answers
SOURCE: pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Posted on Jan 17, 2010
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
How do i trigger my spitronik on jeep grand charokee limited 4.7 V8
what on earth is that
spitronik an
animal
vegetable.
or a mineral.
Feb 23, 2015 | Jeep Cars & Trucks
Does anybody know how the spring catch in nds lite goes back together?
sry didnt quite understand your question but what i can get... its the trigger?? if it is the little spring with a loop of wire goes into the hole with 1 end of the wire going into the trigger then you drop the pin through and then put in the trigger slot then take a small flat screwdriver is what i use and push the wire into the slot that holds it...hope this helps
Mar 18, 2012 | Nintendo DS Lite Console
I CANT GET MY BISSELL SPOTLIFTER MODEL 1716 TO SPRAY THE SOLUTION.
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
May 28, 2011 | Bissell 1716 Spot Lifter PowerBrush...
My throttle continues to stick. The motor races and it sounds like the engine is about to explode because of its speed. I opened up the handle and the spring seems out of place. When I squeeze the trigger...
You should see some small wear marks inside the handle where the spring is supposed to rest. Also, check the throttle cable where it exits the plastic engine housing and goes to the throttle plate on the carburetor. Make sure it is connected correctly and not binding on anything on the way to the carburetor. There really aren't any diagrams or pictures available on the net of the insides of a Ryobi weed-trimmer's throttle trigger and spring.
When you squeeze the trigger the steel cable should move, the cable housing should NOT. If you look closely, you will maybe see how it works and all goes together. It is not that complicated.
May 21, 2011 | Ryobi Garden
Trouble reassembling a daisy buckmaster 840 bb gun. We can not figure out the trigger mechanism in order to fit the side panels back into place.
1) Stack the trigger, seer (long black metal piece) and trigger block (large L shaped silver piece) on top of each other, with the seer in the middle.
2) You should have 3 springs, the long one attached to the end of the seer, the skinny one on the bottom of the seer and the fat one back between the trigger and trigger block on the back side
3) Compress the trigger block and the trigger together thus compressing that spring between them, keeping everything together. Now back the entire unit into the stock cavity. This is tricky and will take some practice. Be sure to keep the pieces squeezed together.
4) Insert the pin through the side which is countersunk. It only goes one way.
Jul 19, 2009 | Toys
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Heating & Cooling Logo
402 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
