Question about Cajun Injector Electric Turkey Fryer
Where to find a replacement electric heating element
Heating electric element went out
Should we repair heat element, or buy a new oven?
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
Mar 10, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
My electric digital smoker wont heat. The timer works fine and the temp sets fine, but the element will not heat up . LAst use was the same problem then it eventually came on after some jostling of the...
Hi tee1134400...
Check all your connections going to the heating element...sometimes they will get corrosion on them and cause them not to function properly.
Please take time to rate me
Sep 22, 2011 | Masterbuilt 20070106 Electric Smoker
Heating element is not working
I would say it could be one of two things. The heating elements could be bad, not likely though as the were working when the dryer was reset. You may want to try changing your circuit breaker, as your heating elements work off of the 2 phase 240 voltage while everything else in the dryer works off 120V. Check the voltage on each phase of the breaker in your electric panel see if your putting out the full 110-120V per phase.
Jan 09, 2010 | Frigidaire GLER331A Electric Dryer
Bake does not heat up. Broil works though
I'm going to take a wild guess and say that you oven has two heating elements. A lower one for general baking and an upper one for broiling (this means that you don't have a broiler "drawer").
If this is the case, then the problem exists with the pilot/ignition system for the lower heat element.
The systems vary by manufacturer, but the type that I'm familiar with involves and electrical heat element that ignites the gas once it starts glowing. It's possible that a wire has been damaged/disconnected or that the heat element has malfunctioned.
If your oven has a pilot, then it's possible that the pilot went out on the lower element and not the upper. Last option would be an electric "spark" style ignition which may have suffered from the same problems as the electric heat element mentioned above.
Oct 13, 2009 | Magic Chef CGS3760 Gas Kitchen Range
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Accessing the heating element
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Feb 08, 2008 | Amana ALE643RB Electric Dryer
Cajun Injector Electric Turkey Fryer Logo
46 people viewed this question
Top Cajun Injector Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Cajun Injector Kitchen Appliances - Other Expert? Answer questions, earn points and help others
