Question about Gateway MT3418 Notebook
GATEWAY MT3418 WONT BOOT UP SCREEN BLANK WAS TOLD MOTHER BOARD IS BAD
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try reseating the memory one stick at a time, one slot at a time.
3 long beeps on bootup,black screen,gateway atxeg lx3 700s po4
This is an indication that there is a memory issue. Reseat the memory in the computer and try again. If this fails and you have two or more sticks of memory, try just one in a slot at a time. Hope fully one chip will fail and you have found your bad memory chip. If all chips fail in one slot, try the other, this would incate a bad slot on the mother board.
Good luck and I hope this helps.
Mar 01, 2012 | Gateway Computers & Internet
I have a gateway 64bit AMD Phenom X3 with an ATI Radeon Graphis Card. The PC worked fine. It was transported during moving and now wont boot up. I was told the graphics card is bad but am not sure what...
If the graphice card was faulty, you would hear error beeps from the PC loudspeaker.
I expect all that has happened is a connector has pulled free and does not allow you to switch the mother board on.
Check all of the connections before spending time on fault finding. All that happened was it has been moved, so it can't be much. Think mechanical.
Hope this helps.
Dec 14, 2010 | Gateway GT5692 AMD Refurbished Desktop PC...
Turn on but no boot . it is blank displaying
Try an external display, to see if the system is working or not.
Aug 17, 2010 | Gateway MT3418 Notebook
I have a Compaq nc6000 that would not boot up. I
Sounds like your display panel is bad or it's another symptom of a mother board flex problem at the Maxim chip
May 22, 2010 | HP Compaq nc6000 Notebook
Black screen upon boot
try to remove the battery and unplug the power adapter. press power button for 30 sec. then connect power adapter. check if the pc able to turn on
Apr 06, 2010 | Gateway MT3418 Notebook
Gateway 3418 wont boot - no video
Sounds like the charger board has a short or the ac adapter is malfunctioning.The battery itself may be the cause but not likely.
Aug 04, 2009 | Gateway MT3418 Notebook
Screen Black on Gateway
yes and no, i never have to replace the motherboard on a computer but i say you probably can upgrade it.
Jun 08, 2009 | Gateway MT3418 Notebook
All the lights of my gateway MT3418 are on, but screen is black
Can you see a background image when get really close to the screen?
Cheers
Sep 24, 2008 | Gateway MT3418 Notebook
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Gateway MT3418 Notebook Logo
340 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
