Question about Lincoln Electric K1170 AC-225 Stick Welder
Replace power switch on 230 lincoln welder
How to replace
3 Suggested Answers
SOURCE: lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Posted on Sep 06, 2010
  • 905 Answers
SOURCE: The switch on my AC/DC
Depending on what exactly is broken (it may just be a set screw), it may be repairable. Contact Lincoln here and ask them for a parts diagram for the switch assembly. That will help you be able to disassemble, and identify what exactly is wrong.
Then you can make the determination if it is fixable or not. Sometimes, manufacturers will have trade-in or trade-up programs as well for damage products. Inquire about this too.
Posted on Sep 11, 2010
I have a Lincoln power mig 216 and as soon as you strike an arc on metal my feed wire either kinks or breaks at the feed rollers and starts rolling out the side I have replaced the tip, liner and diffuser
Are there any kinks in the feed line from the spool to the tip that is causing the wire to not feed? Cut a length of wire and pull it though the feed line to see if there is a lot of friction in it, that would prevent wire feed. Finally, check the wire size - I know, but it is worth checking just in case.
Mar 04, 2015 | Lincoln Electric Lincoln Power MIG 216...
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
I was welding and it just cut off and wouldnt come back on.
CHECK YOUR BREAKER FOR THAT CIRCUT OR RESET BUTTON ON
THE MACHINE.
Sep 20, 2011 | Lincoln Electric Lincoln Power MIG 216...
I have a Lincoln 215 mig which seems to have lost much of its power. What was adequate heat at setting "D" now has to be setting "G". Does anyone know the likely cause and how much it...
Hi:
Before you rush to send your machine to be fix, let's do a little troubleshooting:
Weak voltage can happen due to different problems:
1) Check your ground cable first, if your terminals are "blueish" or with signs of taking too much heat, replace them including your ground clamp.
2) Check you contact tip on the gun and tip holder these must be tight and free from spatter.
3) Check your plug at gun connection also must be tight.
If everything looks good to your eye, then check your invoice all lincoln units have 3 year warranty. Check you local welding supplier if they don't have a direct relationship with Lincoln then take your machine to your local Praxair location and they will contact Lincoln for you. Probably all you pay is the shipping.
If this was useful to you, please vote.
Mar 12, 2011 | Lincoln Electric Lincoln Power MIG 216...
I have a older lincoin ac225s welder I got this from a old man that said it worked . well it has no power cord on it and my question is is the ground wire connected to the point where the ground from the...
Hello, I was a little suspicious about the voltage on this unit. Forgive me if I am telling you something you already know on the power side of this welder. http://content.lincolnelectric.com/pdfs/products/literature/e230.pdf
The welder you have is a 230 volt single phase 60 hz. What you require is a 230 volt connection. The two line wires from the 230 are connected on either side of the switch. The ground has to be connected to the chassis / frame of the welder itself. I would not connect to the ground cable output, I would connect only to the metal chassis of the welder. This is to keep the welder isolated from the main power circuits in your shop.
Jan 28, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I have the lincoln 180 my wire is being fed but not getting any spark any ideas?
First make sure you have a good ground clamp and the line well tight to the machine. This problem is a common one.
Jan 07, 2011 | Lincoln Electric Lincoln Easy MIG 180...
Lincoln electric ac/dc arc welder model ac/dc
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
My 180 MigPak will not deliver argon to the torch. The tank is turned on. But won't let gas flow when the trigger is squeezes. Stick the torch in water no bubbles appear. What could be the problem. ...
Your gas hose or torch could be bad or plugged. Your gas solenoid on the welder itself could be bad. Disconnect the torch gas hose at the welder and see if you have gas coming out of the welder itself.
Jun 28, 2010 | Lincoln Electric Lincoln Easy MIG 180...
Lincoln mig welder 180, 230 volt 20 Amp Input. BUT! Manual says use ''Super Lag 40 amp Double Breaker, Plug on Welder Is Nema 6-50 ( 50 Amp ) Wleder cord is 12awg. What wire should be used to wire it up in...
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Dec 13, 2009 | Lincoln Welding Tools
Lincoln Electric K1170 AC-225 Stick Welder Logo
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
