Question about Nesco Real Tea Tea Maker - -
Power switch stays on - Nesco Real Tea Tea Maker - -
PRECOR C956 power switch wont stay on
The power switch on Precor treads is also a circuit breaker. If it trips when plugged in, you have a dead short in the machine.
Feb 06, 2014 | Precor Exercise & Fitness
Starter stays engaged park or nuetral
Powssible that there is always power to the inhibitor switch. It is the switch that only allows current to flow thru it when in park or neutral. Could be power is always present at the switch when it is in park or neutral. Check the ignition switch first and see if it is powering the start circuit all the time.
Dec 05, 2013 | 2006 Chevrolet Cobalt
2005 Honda Accord 4cyl cruise control does not work
check all your fuses first then take a look at the brake switch and there is a criuse cancel switch also, i think there may be a problem with the switch,even if the cancel switch was bad i think the power would still stay on but cruise would just stop and power would stay on. check fuses and switches anyway to be sure then take a look at the power switch.
May 30, 2010 | 2005 Honda Accord
HP Elitebook 2530p power lights stays on after
are you switching off, or just closing the lid? On most laptops, closing the lid just hibernates and constantly uses power, it can be changed in the control panel power options.
Mar 26, 2010 | HP EliteBook 2530p Notebook
Console light stays green all the time.
Your system's power supply cord could be faulty.
it could be receiving too much current and its making your power supply think the system needs to stay on. try plugging your console into a different outlet or surge protector. if that doesnt work you will most likely have to get a new power supply cable.
Dec 17, 2009 | Nintendo Wii Console
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
E machines model3210 switches on & off.
in bios
disable power options ,such as power on by modem and lan
Nov 13, 2007 | E-Machines eMachines Desktop PC
Nesco Real Tea Tea Maker - - Logo
67 people viewed this question
Top Nesco Kitchen Appliances - Others Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Nesco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
