Question about Maytag Washing Machines
I have a Maytag washer heavyduty commercial quality/oversize capacity plus/710 rpm/22 cycles 8 years old. Having a problem when rinsing. It will not spin the water out
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number?
Posted on Nov 25, 2013
5 Suggested Answers
  • 183 Answers
SOURCE: Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Posted on Jul 30, 2007
duby1990
  • 367 Answers
SOURCE: My MayTag performa oversized capacity washer wont spin
Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
Posted on Nov 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer not spinning/agitat
This problem is usually attributed to a broken motor coupling. The following link provides step-by-step instructions on how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is a small 3-piece component that is installed behind the drive motor and couples it to the transmission. It is common for these small couplers to break as they wear out. The key symptom in determining the cause is the fact the washer will not agitate, but still drains. The reason is because your drain pump is mounted on the front of the drive motor and will still run as long as the drive motor is running. The part number is provided in the link I gave you. A replacement coupler can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best price. Make sure you "Search by Part Number" when looking up the part. This shouldn't cost more than $20. If you do not wish to order on line, take the part number I provided and go to your nearest appliance parts retailer. This is a common item they should have in their inventory.
If you have questions along the way, please let me know. I hope you find this information helpful.
Posted on Mar 03, 2009
  • 336 Answers
SOURCE: 8-24-2009 5:55 P.M. I have a Maytag Performa
It sounds like the belt broke or the lid switch could be bad. Use a screw driver to manipulate the switch with the machine on. If you can tip the thing back enough to check the belt. I hope this helps.
Posted on Aug 25, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
Maytag washer very loud on spin cycle
I know the exact sound you are hearing, I had the same thing several yrs ago on my old Whirlpool. I think it was something with the transmission, but what I needed was no longer available. I found a lot of info by entering the make/model nr in search box at appliancepartspros.com. You could also look atR44U61 RepairClinic.com
May 02, 2017 | Maytag Washing Machines
8-24-2009 5:55 P.M. I have a Maytag Performa PAV3240AWW top loading washer 2-3 years old has worked well for an active family of four until the last load of wash. It seemed to wash and rinse cycle OK when...
Aug 24, 2009 | Washing Machines
Nov 20, 2008 | Washing Machines
Clanking, sparking sound coming from washer
Need to know a little more info. Need to know if this noise starts when you first turn it on (during the fill up cycle), once the actual washer starts (wash cycle) or when it goes into spin cycle.
Jun 11, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Noisy Washer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
132 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
