Question about Fellowes PS70-2 Shredder
Over heating light on, will not work. tried to unplug for an Hour still not working
Hi My Fellowes PS-70 temperature light is on and it will not work. I tried unplugging for about 2 hrs, still not working. Any Ideas? Thanks Scott
  • 328 Answers
Can you hear any humming? Blades or motor may be jammed. Can you get the top off? Most likely there is paper jammed in the cutter asm. You may have to manually turn the motor in reverse to pull the paper out.
Posted on Jun 05, 2009
Cd stuck in the shredder
did you try reversing it?
If it wn't you will have to unplug it and break off as much of the dcrom near the rollers and try run revese back and forth and see if it will clear that way; if not then the shredder has to come apart.
Jul 18, 2014 | Fellowes PS-70 Shredder
Fellows PS-70 shredder basket ajar light is on
Here is some general advice. Shredders have an interlock to be sure they don't run while the basket is not in place. They don't want you holding the head unit and it starts running and shreds your fingers. So you need to look for the switch that tells the head unit that it is in place over the basket. I'm guessing here but it might be something like a little plastic protrusion that pushes into the head unit to activate a swith. It is possible that the little plastic piece is broken and is not activating the head unit. That would explain why the display thinks that the basket is ajar or misaligned. BE CAREFUL if you tinker with the interlock and be sure it is unplugged!! That is an ORDER!
Apr 22, 2014 | Fellowes Powershred PS-70
My fellowes ps-70 shredder has a light on and it's not working
If the shredder is the kind that turns on when you insert paper, it may have an optical sensor that is dirty or blocked. Try blowing off the sensor with some canned air. The sensor is usually located in the center of the paper path slot. Also check that the bin is completely closed. Sometimes a tab on the door is bent or broken so that the shredder thinks the door is open. The tab activates a switch which tells the shredder that the door is safely closed. Fellowes has a lot of good tips on their website.
Apr 22, 2014 | Fellowes PS70-2CD Shredder
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
Fellowes Powershred PS 60CC stopped working
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Jun 13, 2008 | Fellowes PS70-2CD Shredder
PS-70 Shredder problem
Make sure that the shredder is locked down in its case by pushing down on all 4 corners.
Since the basket slides forward to empty it, I would think the safety switch is located in the front but not positive since I don't have a unit right in front of me.
Check to see if you see a slot in the top part of the shredder unit. Usually the basket has a piece of plastic that will line up with the slot when the basket is in place (Safety switch) so that the top part of the shredder knows that the basket is in place.
Look around with a flashlight, If you are going to feel around with your hand, PLEASE MAKE SURE YOU UNPLUG the shredder just to be safe.
Hope this helps.
Good luck.
Mac =)
Feb 10, 2008 | Fellowes PS-70 Shredder
PS-70-2 not working
Make sure the pull-out wastebasket is all the way in. Also, make sure the basket is less than half full. A paper jam could also cause this symptom.
Jan 22, 2008 | Fellowes P70CM Shredder
Fellowes PS70-2 Shredder Logo
295 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
