Question about Dryers
Need a electronic florescent ballast RB-CHD40
5 Suggested Answers
  • 74 Answers
SOURCE: How to replace a tube holder or ballast
You can replace a ballast or tube holder if you're fairly familiar with wiring. 1) Turn off the power to the circuit. 2) Remove the tube and the cover plate that conceals the workings. 3) Disconnect or cut the wires to the tube holder or ballast and remove. 4) Strip 1/2" of insulation from the ends of the wires. 5) Mount the component and connect the wires with wire nuts. 6) Replace the cover and tube. 7) Turn the circuit back on. 8) Turn the switch on.
Posted on Jan 18, 2006
  • 3 Answers
SOURCE: How do you replace starter/ballast in countertop
Yes, probably you'll need special help for that, or simply take off your countertops
Posted on Aug 04, 2010
SOURCE: I need a Rhine Electronic
I had the same prob. no one could tell me were to go including the store we bought the fan from.. Well good news go to efanparts.com and order the ballest by phone..(975)553-4433.man major pain to find..
Posted on Dec 16, 2010
  • 23 Answers
SOURCE: The backlight ballast not working
Change inverter board
Posted on Dec 09, 2013
What is a ballast?
A ballast keeps a tiny charge running into devices that would otherwise need to "warm up" in order to function properly. Non-flicker florescent lights use a ballast so that they come on right away when you flick the switch.
Oct 29, 2014 | Televison & Video
Someone told me to replace something called ''ballast'', what's that?
a ballast is like a transformer, as an example, florescent lights require one between the power supply and the tube.
Jan 20, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
My 4ft fluorescent fixture has whiye and black wires that have been connected, hot and nuetral but it also has a red (brown) wire ? where does this go.
They make dimmable ballasts.
The Lutron dimming ballast shows an orange wire, not a brown >> but other manufacturers might call for different color.
I am guessing here, but ballast should work with Black Hot and White Neutral
I want you to answer back and say if the ballast works with just white and black, Thank you.
Here is a 3-way dimmer to control florescent ballast
Oct 18, 2010 | Lithonia Lighting Lithonia Ps300...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
I need a Rhine Electronic Flourescent Ballast model # RB-CHB 40 for a Hampton Bay Ceiling fan. How or where do I go to get one?
Oct 01, 2010 | Microwave Ovens
I HAVE AN AUDIOVOX LCD WITH SOUND BUT NO PICTURE.HOW DO I FIX IT .WHEN I TRY TO GET INTO THE MENU I CANT SEE ANYTHING
I strongly believe that one of two things has happened:
1) the back light 'florescent tubes' lamp ballast power supply board has gone out.
2) One of the florescent tubes has failed taking out the lamp ballast.
Is the TV still under it's factory warranty?
If it is not I would call around some TV service providers in your area and get some estimates of repair. Fairly common item to go out.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
Top light does not work. Florescent bulb &
even if its a new slim-line unit(T-8 or T-5) and covered from stove smoke,grease,etc. the electronic ballast can go bad, or the contacts on the lamps socket can get dirty from the stoves use
Oct 21, 2009 | Kitchen Ranges
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Use of computer ups for lighting purpose
To your concern of using a computer type UPS to power other devices:
  • If the light is incandescent type, yes;
  • If the light is florescent type, depends on the design. Some yes, some no. If the ballast is electronic, yes; if the ballast is inductive, no;
  • on the fan, no.
To my knowledge, most low-end commercial UPS produces a square wave. Only high end (expensive) models produces true Sine wave.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Computers & Internet
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
