Question about Dell Inspiron 5100 Notebook
Computer keeps turning off due to overheating and gives me that message. air vents are not obstructed
My computer quits running and the message comes up that it is due to overheating. I do not have the air vents obstructed and this has been a recurring problem. what can i do?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Sounds like the cpu fan may not be running like it should, as the laptop gets hot, it should turn on long enough to cool the laptop off.
    See if any part of the laptop feels very warm to the touch.
    Sergeant:
  • 180 Answers
Maybe the fans arent coming on. i just found this little program to control the fans because i didnt think my d800 fans were working. it lets you control the fans and you can see temperatures of different things like hard drive and processor and stuff like that. just play with it a little and see if it helps.
http://www.diefer.de/i8kfan/index.html
Posted on May 08, 2009
GETTING AN ERROR MESSAGE SAYING THAT APPLICATIONS ARE BEING CLOSED DUE TO OVERHEATING.
is this a laptop?
if so there is a good possibility that you may be blocking the air vents where the hot air is pulled off the cpu. also the heat sink on the cpu could be dirty inside the computer . If so it needs to be cleaned. in many cases venting of air is blocked when placed on a soft surface or lap
May 16, 2017 | Computers & Internet
Message keeps popping up saying Turn off computer, problem in cooling system
you need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 25, 2013 | Toshiba Satellite 1715XCDS Cooling Fan...
Acer Extensa 6600 keeps freezing/hanging. I reloaded the operating system and the problem still persists. Most of the time the computer 'gets around to doing the task' but it hangs regularly and does not...
its quite obvious the system is overheating.
try clean the air ducts and make sure nothing is obstructing them (esp when u use them on the couch/bed)
time to change the fans too
Oct 15, 2013 | Acer Extensa 6600 (4400 mAh )
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
HP dv6 overheats, fan runs but little air comes out. Warranty just ran out, of course. On start up sometimes error message is "operating system can not be found"
Overheating is undoubtedly caused by obstruction to air flow in between the fan and the vent. The heat absorbed by the heatsink is driven out by the fan and when some obstruction(usually lumps of dust comes in between, this overheating problem appears. You will have to open it up and clean the path of the airflow to resolve this problem. As for the OS not found option, it is most likely to be due to a HDD crash. See if BIOS detects it. If it does it is not a malfunction and is definitely a crash. I am afraid you will have to re-install windows to resolve this problem.
Aug 29, 2011 | HP Pavilion dv6-1030us Notebook
Runs but does not heat
First check for obstructions in your exhaust vent. It is probably your thermal fuse. It trips due to overheating which is usually caused by a defective heating element, vent obstructions or overloading.
Feb 07, 2011 | Dryers
My Tohsiba Sattilite keeps turning off too AND I play something like Settlers6 then it just turns off i think Toshiba has a problem with their computers and my computer is quite fast and sometimes i hear...
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Dec 07, 2010 | Toshiba Satellite 1805-S274 Notebook
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
Bradford White LP water Heater Power vent ,flame keeps going out
flue is overheating make sure outlet is not obstructed outside and if not that you feel a good air flow coming from it
Oct 02, 2009 | Water Heaters
I think my computer is overheating
you can be sure your computer is overheating if your cursour is lagging or if u see a shadow around it. if so try installing another pc fan with can be found at wal mart or any eletronics store.
Jun 20, 2008 | Computers & Internet
Dell Inspiron 5100 Notebook Logo
508 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
