Question about Fahrenheat Tempra-Sure Programmable Thermostat
Need instructions for Fahrenheat Programmable Tempra-Sure thermostat
Need operating instructions for Fahrenheat Tempra-Sure Programmable Thermostat
  • 499 Answers
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
Help please. We lost instruction manual for our Carrier programmable thermostat. Not even sure what model but looks like a EDGE TP-PRH01-A. It says "Check Filter".
check filter is a setpoint left in the program of the thermostat it does not effect the thermostat peformance check carriers web site or google that number may come up but that reminder does not effect the function .
Aug 20, 2010 | Carrier TSTATHCP Programmable Thermostat...
I can not figure out the wiring for my thermostat. this wiring diagram is worthless to me. I have a fahrenheat single pole thermostat model fta1a. Where do the wires from the breaker box go? It almost seem...
do not purchase Marley Fahrenheat products as they refuse to provide useful installation directions to the home owner. return product to store for a refund in protest of their totally bogus installation directions total junk thanks for wasting my time. I will be sure to smash it before I return it to the store to show my gratitude for the waste of a time web site!!!!!!!!!!
Dec 21, 2009 | Fahrenheat Built-In Baseboard Thermostat...
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
How do I calibrate the temperature for the RTH7500D thermostat? It is 2 degress warmer than the thermostat reflects. Does this thermostat operate on the battery power alone? There are only two wires going...
There is no feature in this thermostat to adujust sensor. You need to make sure you have picked for hot water systems.
Follow blue link for instruction manual
If you need more information, please post back.
If this answers your question please hit accept
Nov 27, 2008 | Honeywell Electronic Programmable...
Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Tempra-Sure Programmable Thermostat Logo
203 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
