Question about Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater
My mini max 100 is kocking and short cycling - Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Not enough water flow if you have a bypass shut half way
Posted on May 08, 2014
2 Suggested Answers
  • 139 Answers
SOURCE: I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Posted on Jun 21, 2009
Wiring to gas valve on Pentair mini max 100
should be schematic in unit if not contact Pentair they will send you a PDF file
Jul 24, 2015 | Pentair Pool & Spa
Turn off service light
What exactly is the heater doing. You turn on the filter pump, flip the switch on the heater, does it turn on? Does the board light up?
Jul 18, 2014 | Mini Max 100 Above Ground Heater
Inspiron mini fail to power on
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 21, 2013 | Dell Inspiron Mini 10 Notebook
Battery wont charge
Oct 06, 2012 | Dell Inspiron Mini 10 Notebook
Low mileage on tvs max 100,how to increase ?
Try a high octane gas grade at least 89 or high and use a gas additive to remove ethanol from you gas, I use StarTron enzyme additive it is a must on any motorcycle, ethanol is ******* 4 cycle engines! Good luck, Rick.
Aug 04, 2011 | 2011 TVS Max 100
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
I need to know what the fuel to oil ratio is on my Stihl mini boss chainsaw
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you want to verify my recommendation.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 04, 2010 | Garden
Dell Latitude D800-Win XP- My Dvd/rw wont write
Because you lost two devices, the DVD and the wireless mini card, I believe your problem is a drivers issue.
You should make sure you do not have any Malware that is removing these drivers.
If you have access to the Internet download and install Malwarebytes. It has a quick scan that will ID any infections.
Then get the newest drivers for those two devices from Dell's support site.
Before you install the drivers, remove those devices in Control Panel.
Mar 20, 2010 | Dell Latitude D800 Notebook
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Just wanted to know if the mother board 865GM3-LS supports 1Ghz of AGP graphics card..
Motherboard has a AGP 8x ( 1.5 V/ 0.8 V ) slot.
Check the specs on the graphics board you are going to install. Make sure that it meets these specs.
Here are the specs for your motherboard: General Product Type Motherboard Form Factor Micro ATX Width 24.5 cm Depth 24.5 cm Compatible Processors Pentium 4, Pentium 4 Extreme Edition 64-bit Processors Compatibility Built-in Processor Socket Socket 478 Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz BIOS Type Award Storage Controller ATA-100, Serial ATA-150 Processor Installed Qty (Max Supported) 0 ( 1 ) Memory Supported RAM Technology DDR SDRAM RAM Installed ( Max ) 0 MB / 2 GB (max) Supported RAM Speed PC2100, PC2700, PC3200 RAM Features Two DDR channels Video Graphics Controller Intel Extreme Graphics 2 Video Memory Shared Video Memory (UMA) Audio Audio Output Sound card Signal Processor Intel 865G Audio Codec Realtek ALC655 Sound Output Mode 5.1 channel surround Compliant Standards AC '97 Telecom / Networking Networking Network adapter - Realtek RTL8100C - Ethernet, Fast Ethernet Features BIOS Features Hyper-Threading Technology Expansion / Connectivity Expansion Slot(s) 1 ( 1 ) x processor - Socket 478
2 ( 2 ) x memory ( 2.5 V ) - DIMM 184-PIN
1 ( 1 ) x AGP 8x ( 1.5 V/ 0.8 V )
3 ( 3 ) x PCI ( 3.3 V/ 5 V ) Storage Interfaces Serial ATA-150 - connector(s): 2 x 7pin Serial ATA
ATA-100 - connector(s): 2 x 40pin IDC Interfaces 1 x storage - floppy interface - 34 PIN IDC
4 x Hi-Speed USB - 4 PIN USB Type A
1 x audio - line-In - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone 3.5mm
1 x mouse - generic - 6 pin mini-DIN (PS/2 style) Additional Connectors (Optional) 4 x Hi-Speed USB Miscellaneous Software Included Drivers & Utilities Compliant Standards Plug and Play
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 10, 2009 | Computers & Internet
Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater Logo
78 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
