Question about Sharp CD-DD4500 System
Where can I find a replacement antenna for my sharp CD-DD4500?
I got this from my mother and she can't find the antenna for it , where can I get one from?
Where can I get an antenna for Sharp CO-C3800 stereo?
It depends on the plug of the antenna on the system, if it is a female RF plug, you can use a normal bunny ears antenna with a female to female adapter.
Oct 26, 2013 | Sharp CD-C3800 Shelf System
How do i turn my timer off on my sharp dd4500 stereo without tbe remote can someone help me please
You can do it by its main menu option. Go to timer setting tag, and set it to Zero.
May 25, 2013 | Televison & Video
I need a FM antenna X 1 (92LFANT1535A) for Sharp Mini Component System model CD-DK890N
Try these web sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Sharp+mini+cd-dk890n+parts&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://www.partstore.com/Model/Sharp/Sharp/CDDK890N.aspx
Jan 20, 2013 | Audio Players & Recorders
I want to use my ipod through the headphone jack. is this possible and what settings need to be on to do so
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for
standard stereo to any audio device with a standard RCA input (except one labeled "PHONO").
Get a cable like the one described here: http://www.monoprice.com/products/product.asp?
c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 09, 2011 | Sharp CD-DD4500 System
My model is one pictured on your "Ask a Question".
quick-start guide:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/
Audio/QuickGuide/Archive/aud_qguide_cddd4500.pdf
operation manual:
Audio/Manuals/Archive/aud_man_cddd4500.pdf
Apr 28, 2011 | Sharp CD-DD4500 System
I am looking for a replacement antenna for my sharp cd-ba250 stereo
if you have an old rabbit ear antenna from your old TV that will work
Jun 07, 2010 | Sharp CD-BA250 CD Shelf System
My dog chewed up the wire that go's into the socket and now we rewired it and the cd player doesnt work anymore how do i resove that problem?
sony makes the cheapest cool lookin **** expect this in the future my friend replace tis a shame i know
Oct 31, 2009 | Sharp CD-DD4500 System
I have no antenna and radio doesn't play. I need an antenna or specs on the plug to make my own
Looking at Sharp's site, you have a 3 pin plug that goes into the rear of the unit. the top pin is FM the middle and bottom are AM. You can get female "bullet" connectors and make your own if you wish. Or you can order it from Sharp. Probably under 20. Hope this helps
Jun 26, 2009 | Sharp CD-BA2600 CD Shelf System
While playing the DVD of Dark Knight on my 5.1 surround system last night, my audio system would simply turn itself off.  It seemed to happen during moments of extreme sound, i.e. explosions, gun shots,...
this is a common problem with this unit the main thing is a low grade capcitor that the manufacturers used which is known to discharge all of its power at once which it recieves a high signal output and tells the unit to shut down the solution is very technical but basiclly you gave to install a higher amp capacitor.
Dec 19, 2008 | Sharp CD-DD4500 System
Sharp CD-DD4500 System Logo
18 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
