Question about Sport & Outdoor - Others
Tetherball i need to tie a know that wont release when I play tetherball
What are the dimensions of a tetherball court?
60 feet (18 meters) long and 30 feet (9 meters) wide.
Jan 17, 2013 | Sport & Outdoor - Others
How can I attach a ball to a rope to make a tetherball game?
You can buy a tetherball ready made - however if money is tight you could always make your own by attaching a rope to a volleyball, you can make a hole in the sponge ball and pass the rope through it and tie a huge knot at the bottom.
I want to make a tetherball pole stay in the ground without falling over, how can I do this?
You should dig a hole that is about 2 feet deep, you should get a pole which is 2 inches thick and 12 feet long. Place the pole into the hole so that 10 foot of it is sticking out of the ground. Fill the hole with cement and wait for it to dry. This should be enough to keep the pole in place when swinging the ball.
How tall should the pole be in tetherball?
If you are going to make a tetherball pole you should make it at least 10ft tall (roughly 3meters) from the ground.
Jan 13, 2013 | Sport & Outdoor - Others
What is tetherball?
Tetherball is a fun sport where two contestants swing a volleyball that is attached to a pole with rope. The idea is that one contest will swing it clockwise and the other anticlockwise - a player wins when they manage to swing the ball so that it is wrapped around the pole and can't swing any further.
What's your problem?gear shifter wont come out of park
Must be the release mechanism tied to the brake pedal is loose or bad. don-ohio
Oct 30, 2011 | 1993 Mercury Grand Marquis
Trunk lid wont open
Most likely, the plastic snap on the end of the hooked link that runs from the button mechanism down to the latch has popped out of its hole in the latch. Common problem on cars of this age.
If you have fold down rear seats, crawl in the trunk and pop up the plastic snaps that hold the trunk liner in place (if you break some, no worries, they are cheap), and pull up the liner and reach inside and release the trunk latch. Then you can replace the plastic snap on the link, or just secure it to the lock with a zip tie. We bought a new snap and still had to secure it with a zip tie.
If you don't have fold down rear seats, you will need to remove the license plate and drill a hole so you can reach in with a wire hook and release the trunk latch. You need to find a rubber body plug an inch or so in diameter and then drill a hole to fit your rubber plug. This will be easier if you know someone else with an e36 who will let you pull off their trunk lid lining and see what it looks like so you can select the best spot to drill the hole and know just how to grab and pull the trunk latch to release it.
Mar 12, 2011 | 1997 BMW 328
Front end shakes
Several things could cause this. Look at the inner tie rod end bushings. They are behind the engine block and are easy to replace. You can check this by holding onto the tie rods and seeing if they move back and forth. If not, the go to the tire. Holding the tire at 9 and 3 (clock times) try to shake it back and forth. If there is a lot of play (movement) This could point to either your lower ball joint/control arm assembly, or your outer tie rod ends. Both of these fixes are pretty easy if you know how to work on cars at all, but you will need to get it alligned after you are done doing the work. Also, if the lower ball joint assembly is out, a lot to times you will feel a clunk in the break pedal like your breaks are releasing at diffrent times. (you can also hear a clunk.) I have more ideas, but this is a good place to start because the parts aren't too expensive. If you need advice on replacing these parts, I can give you a hand with that too. Good luck.
Sep 22, 2010 | 2002 Dodge Intrepid
Sont bdp300. Has all firmware updates and says it cant play disc. Plays all other blu ray just wont play some of the latest releases??
Just wait for new firmware, if this is common problem then firmware will be released shortly, mean while it doesn't hurt to give sony a call, just to fined out if they know about this problem.
Nov 28, 2009 | Sharp AQUOS Blu-ray Disc Player
Sport & Outdoor - Others Logo
35 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
