Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
How to change a phone number in the memory - Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
I have a Sanyo Compander plus mode; CLT-1861 bouth 15 years ago. I lost the instructions on how to program phone numbers into it. Will it be possible to get them back................ Thanks. Carole
to store numbers.
1 press memory.
the talk indicator flashes.
the dialing buttons light for approximately 10 seconds.
2 dial the phone number you want to store.
3 press memory.
4 press a number ( 0-9 ) to assign a memory location number to the phone number.
a beep sound. the dialing button light goes off.the phone number is now stored in the hanset memory.
5 repeat step 1-4 to store other numbers or to change previosly stored numbers.
my name is jean( french for john) e-mail is morin.j2@videotron.ca
Sep 18, 2011 | Cell Phones
How do i change phone numbers in stored memory
hi
if you want to change the number that have already stored means,just go to contacts in your phone that you want to change it.then select option menu and choose edit.here you can change the phone numbers that you have stored in the memory
thank you
Dec 17, 2010 | Cell Phones
I have a GE phone, mod # 2-9223BKC. I want to program numbers in but i can't find the directions, can you help
MEMORY
Each memory button is capable of storing phone numbers up to 16 digits. Memory
locations 0-9 require you to press the mem button for access.
STORING A NUMBER IN MEMORY
1. Pick up the handset, and press the store button.
2. Dial the number to be stored (up to 16 digits).
3. Press store again.
4. Press a memory location button 0-9, and hang up the handset.
INSERTING A PAUSE IN THE DIALING SEQUENCE
Use the redial button to add pauses to a dialing sequence, for example after you dial
9 for an outside line. A pause is approximately 4 seconds long.
CHANGING A STORED NUMBER
To change a stored number, you just replace it with a different number using the
procedure for storing a number.
DIALING A STORED NUMBER
1. Pick up the handset, and wait for a dial tone.
2. For numbers stored in memory locations 0-9, press the mem button, and then
number of the location in which the desired number is stored
Sep 15, 2009 | Lands Phones
I cant get the memory lock off to change the phone numbers
http://www.buymebuyme.com/retail/manuals/nortel1500cw.pdf
Apr 17, 2009 | Office Equipment & Supplies
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Format phone memory
If you haven't ever changed your security code then you can use the default code which is 12345. If you have changed the default code, then you can use your IMEI number to calculate your security master code. For this please pass me your IMEI number.
Cheers. Thank You.
Jul 13, 2008 | Nokia 6270 Cellular Phone
How do I change my phone numbers that on automatic dialing?
It was easy - I found my instruction pamphlet. Thanks..
The phone must be off when you store numbers.
1. Press the memory button.
2. Press a number key (0-9) to store the dialed number in that memory location.
3. Press the memory button.
4. Enter the number (up to 20) digits.
5. Press memory button to comfirm. You will hear a confirmation tone.
Jun 27, 2008 | GE Lands Phones
Change/add #'s in Memory
Find your model number and then click this link to download the manual
Manual page
Jan 18, 2008 | Uniden Cordless Phone
Nokia 6233, mobile asking security code to set "phone memory" for saving contacts.
It's a 5 digit number.
You should have a:
PIN,
SECURITY,
PUK, numbers
PIN locks your SIM card.
SECURITY locks your phone.
PUK unblock everything.
Dec 27, 2007 | Nokia 6233 Cellular Phone
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
