Question about Aiwa XR-M33 CD Shelf System
Line level voltage
Need to know line level voltage output.  Is it less then 1 volt
    Novelist:
    Champion:
  • 219 Answers
As far as I know it is about 1 or 2 volts.  Probably closer to 1 volt peak to peak.
Posted on Oct 11, 2007
SOURCE:
I need to know the outpout voltage of my numark ttusb power transformer
the usb output is off course 5 volt. Your phono output you can measure with a reasonable meter, depends on the needle and your line output is something you really need to know , since it's a constant , just like usb which has four leads. Two with a constant voltage 0-5. and the other two are for data transport.
Jan 02, 2015 | Audio Players & Recorders
After programming irritrol auto watering system I push the function switch to run and it turns the watering time to off so nothing happens. Voltage at the 24 volt terminal is 13.2 volts, however when
The typical lousy power source for this system is likely defective. They will normally rise to 140-150% of nominal voltage (24V) and settle around the required voltage when loaded.
Check the supply (if separate) for a rating of voltage and current; for example: "24VDC/XXMa" where the 'XX' is the current that will either be in milliamperes or amperes.
To correctly measure the voltage, you must know first if it's output is AC or DC.
If this is a DC supply, it probably has a failed diode, if AC, the transformer is bad.
A less likely, but possible problem, is that the programmer itself has an internal failure and is overloading the supply.
If you have a meter with a separate 10A jack, and you can interrupt either side of the supply line, try measuring the load current.
This will however, only be possible if the 10A can measure both AC and DC or if you know that the supply output is DC.
Nov 22, 2014 | Cars & Trucks
What should the output voltage be from the controller on a pride victory scooter?
Try searching up said scooter voltage on google and check lots of forums
Nov 06, 2014 | Pride Health & Beauty
Can I use a JX-S900 Y/C separated I/O to run two subwoofers out of same reciever??
Yes, on two conditions:
1) the JX-S900 needs to be a proper matrix switcher. It has to have the ability to route 1 input to more than one output.
2) the sub signals need to be low level RCA/phono, and not high level speaker wire connections. That's not just about the type of connector. It's about the signal going through those wires. A low level RCA/phono sub connection conducts a maximum 0.7 Volt. A speaker wire connection can transmit 30 Volts! If you put 30 Volts in to a line level switching device such as the JX0S900 you'll fry it.
Provided that the above two criteriia are both met, then yes it will work.
  • Connect the AV receiver's sub out to Source 1 - white RCA phono.
  • Connect the two subs mono LFE Left input (white RCA) or the single black RCA/phono inputs to the JVC's outputs 1 and 2 - white RCA/phono.
  • Set the source routing: input 1 goes to output 1 and 2
Sep 17, 2014 | Audio Players & Recorders
Voltage gauge drops alternator squeals. When using plow
INSPECT BATTERY ELECTROLYTE LEVEL
INSPECT BATTERY CABLES/TERMINALS
LOAD TEST BATTERY,_______VOLTS @ 150 AMPS (Min SPEC 10.2 VOLTS @ 150 AMPS.)
INSPECT BELT(s),
TEST ALTERNATOR OUTPUT (ON THE VEHICLE,'NOT' BENCH TESTED),
1 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW not ENGAGED
2 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW ENGAGED ALT OUTPUT SPEC ????
If you need further help, reach me via phone at https://www.6ya.com/expert/ralph_2f0886b7d6af32ce
Feb 04, 2014 | GMC Sierra Cars & Trucks
Output shaft speed sensor
in checking the output signal to the pcm hall effect type sensor. raise car disconnect the pcm connector . turn key on engine off, transmission in neutral. hold one wheel stationary while turning the other wheel and measure the voltage cycles on the pcm connector positive and negative. in each cycle the voltage should rise to 5 volts and fall below 1 volt in a regular cycle. observe several cycles
Aug 23, 2013 | Lincoln Cars & Trucks
Blinking red light of death. 5 blinks. After holding power button while power on for 1 minute and then pushing agaiin I got 1 blink. Set has not been used that much as it is in the bedroom. One source...
Hi Billy,
5 blinks is an error code for 5Volts malfunction either on the P board(power supply) or the A board (main board).
1 blink is an error code for A board (no communication between the system CPU and panel CPU).
Since you've got 2 error code which are both related to A board, I've suspected that the A board is already faulty but you have to confirm it to isolate the P board from fault.
You have to check the 5 volts output of the power supply using the multimeter set in DC voltage measurement. Measure the output of the power supply board through connector P7. If you are getting 5volts on that connector you have to replaced the A board to resolve the issue. If there's no 5 volts output then the P board is faulty.
Faulty electrolytic capacitor can drop the output voltage. Let say you are only get 3 volts or less on the 5volts line, then suspect faulty filter electrolytic capacitor. Most of the time it has a physical indication of fault like bulged/dome at the top and can be easily identify through visual inspection like in the sample picture below.
11_22_2011_12_37_20_am.jpg<<< with dome at the top
If the 5volts line dropped its voltage, you have to disconnect the load and then re-measure it (do it very quick, don't let it turn on for a long time without the load). If the 5 volts line normalize after disconnecting the load (A board) then the fault is on the A board and not on the P board. If the 5 volts line still not intact after disconnecting the load, then the fault is on the P board (5volts line).
I've provided a link below for the suspected boards.
A board (Main Board)
P board (Power supply board)
Note : before ordering online, double check the part no. of your board that is printed on the white sticker on the board itself to ensure you will get the exact replacement. There's some instances that the manufacturer used different version of the board even on the same model no.
Please let me know if you need further assistance.
Ratings and feedback are highly appreciated.
Hope I helped you.
Have a nice day!
Jdvillanueva
Nov 21, 2011 | Panasonic TC-P42G10 Plasma TV
NO SOUND WITH EVERYTHING PLUG IN .
I assume that you're talking about the output from the 2 RCA Phono Jacks? Does this turntable output a "Line Level" signal, or a standard millivolt level 'turntable signal'? If it is an older 'standard turntable', then you need to run it into an amplifier that has a "PHONO" input and ground wire. This will amplify the tiny signal to a 'line level' signal that you can record or run to a computer, etc. If you do not have an older amplifier with "PHONO" input jacks, then you need to buy a separate stand-alone 'phono amp/preamp' that will boost your (tiny 10mv) turntable cartridge levels high enough (.5 to 1 volt) to record on another device. Let me know if that is the case. Good luck.
Jul 24, 2010 | Technics SL-1200MK2 Turntable
Intermatic timer 2-wires in & 2-out. I have "A" neutral, line 1 and load #2. 2-wires in go into load and line. Out do I go neutral and line 1?
You did not give the exact timer type, but most Intermatic mechanical types have more or less the same terminals:
A - Neutral input and load - together
1- Input - Hot Wire
2- Output - time dependent Hot Wire - to load
GRD - Ground can or can not be connected.
I hope it will be useful for you.
Jul 20, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
No phono inputs?? You will need a phono to line level preamp to use aux input.
Nov 03, 2007 | Audio Players & Recorders
Aiwa XR-M33 CD Shelf System Logo
136 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
