Question about Asrock P4 COMBO P4/S478+LGA775/848P/DDR400/SATA/A&L/ATX Motherboard (MOTASR28)
ASROCK P4 COMB- BIOS PROBLEM
I have this asrock P4 COMBO, when i start my pc i cant see the usually appearing in the upper left corner when it is starting up, and my monitor wont detect my pc, i hv a video card, i look of the fan of my video card and it is running. i think i hv a problem in my BIOS. Kindly help me regarding this problem. Thanks and more power to fixya.
  • brillpernell May 08, 2009
    everything u ask me is in proper order, i mean everything is in plugged, and ive been using a long time now, one day i open it as usual, then thats what happen.
    Problem Solver:
  • 9 Answers
Ok I need you to be very specific with the problem, when you turn on the pc, What happens, exactly??.
According to what you say, you have no video. That could mean 100 things, from your monitor being broken to faulty CPU or chipset, video card, melted transistor on the MB or simply a bios misconfiguration.
1st) your pc usually has 2 Leds (or more) One that's always on and one that flash intermittently. The one thats always on is the power led, you should see that one all the time. The other one is the HDD activty indicator.Now I need you to tell me if the flashy led is working, does it start flashing?, listen closely for Hard drive activity. Can you hear the hard drive working?
2) Unplug your monitor from the video card's connector. Turn it off and turn it on. Now it should display some message indicating theres no signal, or that motior is in power save mode or whatever. If it doesn't, chances are big the monitor is broken.
3) if 1- you can see the flash led blinking, and 2- your monitor displays a message when unplugged from the PC; Try connecting your monitor to the onboard video card's port, see if it shows now.
4) if 1- Is true and you can hear HD activity and the led blinking, try connecting your pc to another display, or a tv if you dont have one. Most video cards have a DVI or HDMI port which you can connect to most modern TVs.
5) if 1- is false and 2- is true(monitor shows a message) Then remove you pc cover and get into the Motherboard. If you have the board's manual, look the section clearing CMOS, or Reset bios.
If you don't have the manual then wtch this:
http://www.youtube.com/watch?v=g-yalVoRJSc
Wait at least 2Min bedore puting the battery back in place. Now
if after this, the problem remain the same:
6)Remove the memory. Turn on the pc, it shoud produce some short and long beeps. turn it off and put only one stick. try again.
Switch the memory stick, try a different bank. Watch another video in youtube if you have no clue how to get the memory out.
Be carefull cause mem is really sensitive. I recommend you touch some non painted metalic object before touching the memory.
I hope this solves the iissue. Post the results.Cheers.
Posted on May 08, 2009
Ok first things first, did you just installed the video card?? if so remember to connect your monitors cable to the new video card's port. check your power supply meets the cards requirements. Cjeck you connected your power supply to the video card.
Did you do anything to the pc, Did you changed the biios settings. What did you do the last time you used your computer. If you messed with the bios, thres usually a jumper in the motherboard to reset the bios to defaults settings, It says clear cmos or something like that. You have to take it out and put it in the pins stated. wait 30 seconds and put the jumper back to it's original positon.
If is not this then be more specific so Me or anyother can help you out. Cheers.
Computer not giving output to screen
Looks like a BiOS chip problem.
The bios on your board is the lifeline when starting your computer.
Pull out the bios chip and clean the contact points.Pull out the mem battery back up and flash the bios memory.Pull out all the hardware board on the PCi socket.
Put back the bios chip and flash jumper back after wards.
Restart......If BiOS shows up on screen you got a chance to revive the MoBo, if not.....Check the capacitors near the processor and look for any bloated caps. and replace it w/ the same value.
If no bloated caps.......... Sorry to say, you have to replace that board and upgrade to a higher type.
Hope that helps!
Dec 01, 2011 | Asrock P4I45GV...
I need DRIVER For ASROCK P4I45GV Bios P3.00
http://www.asrock.com/mb/download.asp?Model=P4i45GV%20R5.0
Sep 05, 2011 | Asrock P4I45GV...
Hi! I just made a cpu swap on my asrock p4 combo from socket 478 - 775, the new cpu is the 570J 3.8 ghz 800 mhz fsp 1 mb chache ofcourse i looked at the manual and changed the jumper settings from...
According to the Asrock site, the CPU you chose should work in your board. You are going to have to check the jumper settings, (see the manual page 11) jumpers J1,J2,J3,J4,J5,J6,J8,J9,J10,J11,J12,J13,J18,J21 only. You indicated that you also changed J7,J14,J15,J16,J17,J19,and J20 since your statement was "i looked at the manual and changed the jumper settings from J1-J21"
Also make sure you do not have a jumper block on the CLR CMOS down near the battery. If you left a jumper on, it will not boot
Also, make sure you installed the CPU correctly and did not accidentally bend a pin on the underside. see 2.2 on page 12 Installing the 775.
Dec 23, 2010 | Asrock P4 COMBO...
Asrock p4i45gv not detecting hd 3650 agp card
Take the new card out and reconnect the monitor to the on-board VGA. Boot up press F2 and enter the bios. Look for resource configuration and set the Primary Graphics Adapter as AGP.
Save and switch off. Disconnect the PC from the mains, fit the new card and attach the monitor cable to the new card.
Make sure to attch a power connecter to the card if it needs it.
Reconnect the PC to the mains switch on and hopefully away you go.
Best of luck.
Jan 28, 2010 | Asrock P4I45GV R5 Motherboard
Asrock P4 combo faking death
Friend, Please check to see if the red line on the cable connecting the HDD and the combo etc is towards number 1 connecting pin both on the combo and on the HDD. If not so then correct it right away as you may burn the motherboard or the combo or the HDD. It is a red line on the outside of the cable connecting the HDD or the Combo to the IDE prot on the motherboard.
Nov 05, 2009 | Asrock P4 COMBO...
Asrock fsb800 prescott 800 motherboard driver
hi guys have a good day hmmm i just wanna ask you... if you dnt mind.. how can i download Asrock fsb800 prescott 800 motherboard driver setup??
Oct 08, 2009 | Asrock P4I45E-R3 P4 845E FSB800 DDR400...
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Computers & Internet Logo
231 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
