Question about Water Heaters
Rheemglas fury model 82sv50-2
Makes noise when heating
SOURCE: Rheemglas Fury DV leaking?
Rachel,
I don't know if you have resolved your issue by changing the T&P relief valve. However, if you have replaced it and it appears to have resolved the problem ... it will most likely be only a temporary resolve. And what has happened, it that the water that was being relieved via the T&P valve is now unknowingly leaking / being relieved by a toilet or some other means.
The reason of the leak in the first place is that the most likely the water purveyor has recently installed a DCV (dual check valve) at or within the water meter location. Not knowing where you live, but we are in NC and these DVC's are being installed all over the country.
Basically, your home's plumbing system used to be an "open system" and not it is a "closed system". In earlier times, when the water heater cycled it heated the water, which cause the volume to thermally expand ... and the water was pushed backwards through the meter and it did not allow the water pressures to build. However, with the DCV installed ... now when the water heater cycles and expands water, with no place for the excess water volume to migrate, it now causes a hydraulic effect within the closed system ... which causes the water pressure to become elevated, ultiamtely being relieved at the T&P ...
Here are a couple of links from Watts ....that will help.
http://www.watts.com/pro/divisions/watersafety_flowcontrol/learnabout/learnabout_thermexpansion.asp
http://www.watts.com/pro/divisions/watersafety_flowcontrol/support/support_DETsizing.asp
Locally, we have been on the Cross Connection / Dual Check Valve crusade since early in 1991. We concur that the check valves warrant installation. However the Buidling / Plumbing Codes are not up to speed with truly what is going and how much damage to personal property is occurring with failed water lines ... both inside the home and outside.
Best, Gary H.
Hestand Associates / hestassoc@aol.com
Posted on Feb 01, 2009
  • 92 Answers
SOURCE: flush Rheemglas Fury 22VR75 yearly-increase life of H2O heater?
yes you will increase life if you flush sediment yearly
Posted on Apr 16, 2009
agent91
  • 2100 Answers
SOURCE: How do I turn up
You have 2 thermostats inside of those covers, little things with a dial on them, turn them with a small screwdriver, Don't go too hot or you will be scalding everybody. Hope this helps.
Posted on Oct 05, 2010
SOURCE: I need anode rod for
Anode rods are generic and available from local plumbing supply store or internet.
Just cut it off so it drops into the tank without touching the bottom or sediment on the bottom.
If there is not enough room above the tank to install new rod, then buy anode rod with sausage links.
http://waterheatertimer.org/Replace-anode-rod.html
Open following link for Rheem parts: page 7 shows anode rods
http://waterheatertimer.org/pdf/Rheem-parts-list.pdf
Posted on Jul 04, 2011
SOURCE: rheemglas fury model # 41V50
I have a 50 gl rheem the pilot it doesn't stay lite.
Posted on Jul 21, 2011
What kind water heater can replace Rheemglas fury 81vp20s?
what ever kind you want of course gas for gas and electric for electric
Jan 14, 2015 | Water Water Heaters
I have a Rheemglas Fury model # 81VP207, no hot water it is in a trailer home. HELP
I don't recognize the models number, if your water heater is an electric, check the two-pole circuit breaker in the distribution panel to make certain it has not tripped. If it has, try resetting it. If it will not reset, the heater element is probably bad. If the breaker has not tripped, either the thermostat(s) or heating element(s) are bad.
If it's gas, there are several problems that can cause a heater to not start. First is the pilot lit? If not, try holding the gas control down in the pilot position and light it using a match. (The instructions are on a label on the side of the heater). After the pilot lights, turn to "on" position and it will start to reheat the tank. If the pilot will not relight, either the gas control is failed, or (more likely) the thermocouple has failed. (The thermocouple is a very small copper tube that screws into the gas control and the other end is positioned in the flame of the pilot (it monitors the pilot flame to make certain the pilot is burning and only if satisfied, will allow the gas control to turn on and heat the water in the tank).
Hope this helps.
Dec 14, 2014 | Water Water Heaters
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
I have a Park Model RV with a Rheemglas Fury model 81VP205 with no bottom drain. How do I drain the water heater to winterize for the cold Northern Winters?
Make sure it's off (hydro) and open drain at cold line going in bottom wherever you find a drain (usually close to it) going down through floor and outside under trailer. Follow cold line back until you see a line "T" and one line going down under trailer, and open it up underneath. Then open pressure relief valve at top of tank to allow for faster draining .
Oct 14, 2011 | Water Heaters
The water leaked out overnight. We have not tried to start it again as it is still dripping water. We have a rheemglas Fury Model # 22-40 natural gas.
Open following link to troubleshoot cause and solutions for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Rusted water heater must be replaced.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
For money-saving water heater information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Rheemglas Fury Model #81V52S C, MFG date 05/2003, 50 gal Does not heat properly--not long enough. I Cannot find a gauge, or know how to adjust tempeture--hope that is only problem--please...
One of the elements may be bad. With the power off check each one with an ohm meter. Should show continuity.
The tube the cold water come in through goes to the bottom of the tank. If it has come loose and the cold water stays on the top you wouldn't have much hot water.
Jan 01, 2011 | Rheem Water Heaters
How do I turn up the temp on my Rheemglas fury 82V80-2?
Oct 05, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water discoloration. Rhreem serial rh0909ff00279 date 9/2003 model 8v520c 50 gal electric rheemglas fury. prolem occures when we use hot water. tried fixing...backwashed, drained water out completely...
Brown discoloration is evidence of a rusting or corroded steel pipe somewhere in you plumbing system. Trace the water lines back from the faucet and replace all the steel pipe.
White discoloration is minerals that separate out when the water is heated.
You can change the Anode Rod and it should help. It is not an instant fix, the rod will take a week or two to do its job.
If your water heater is still under warranty, call Rheem, they may replace the water heater free.
Sep 07, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
47 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
