Question about Motorola Mobility S11-Flex HD
S11-flex is connected but no sound coming through from laptop
I am connected it shows paired it shows up under test that it is working properly but no sound is coming through
Have using my 527-s11 as a vga monitor on my desk top fine for over a year now it just stopped working showing the message no signal???
Sounds like it's the mobo on the television...If it's still under warranty, a manufacturer's warranty should cover it as it's considered as a defect in the television. Contact customer support about it, they should be able to solve you issue by either repairing it or getting you something new.
Feb 22, 2015 | Syntax Olevia 527-S11 Television
S11-flex hd not pairing to iphone
Hello Sandy Mayhew,
To connect your S11-FLEX HD with other devices follow the steps below:
1. Turn Bluetooth on for your other device. (phone, computer, etc.)
2. Turn headset on. (Please ensure device is charged)
3. Enter passcode, if prompted, on your other device. Passcode is 0000
4. When complete headset will say "Device 1 connected".
If an error is displayed, you can reset the settings to factory: press and hold the Power & MFB buttons together, then select Reset headset and try again.
Regards,
Lester S.
Motorola support
Oct 26, 2014 | Motorola Mobility S11 Flex Hd...
How to pair my s11-hd to my iphone
How do connect my S11 FLEX HD to other devices Ensure you know how to have your iPhone search for devices after you get S11-hd in pairing mode.
May 23, 2014 | Motorola Radio Communications
Sound Still Play through Speakers when Headset Connected
Most computers will only pair this earpiece as a headset for voice calls. You need to make sure the headset is paired with your device as both a phone headset and media headset. Check your settings on your computer or smartphone to make sure it is paired properly to play media sound.
Apr 13, 2014 | LG HBS-700 Bluetooth Headset
S11 will not charge. Red light blinks on for a brief second and then goes off, and does not charge.
If still within one year of purchase with proof of purchase , give us a call. We'll replace it. CONTACT US
Motorola Support
Aug 11, 2013 | Motorola Mobility S11-Flex HD
My samsung galaxy s11 phones doesn't connect to my car
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | 2012 Volvo XC60 3.2 4dr SUV 3.2L 6-cyl....
Plantronics S11 head set does not work: hooked up properly, but non of the configuration setting yield tone. At one setting, only after the line goes into fast bipping mode (off hook for a long time) I can...
The Plantronics S11 headset system is meant to plug into the handset jack on your phone not the headset jack. Check the connection on the S11 to make sure the handset jack is where it is plugged into at.
Here are a few suggestions from Plantronics if you are not getting a dial tone:
Make sure all cable connections are correct and firmly in place.
Pay special attention that handset cord is properly connected.
Ensure AC power adapter is connected and power is on.
Make sure you have pressed the headset button and the headset indicator is on.
Make sure the telephone handset is off-hook.
Adjust listen volume control.
Adjust the compatibility slide switch.
Ensure that the headset is centered on your ear.
Good luck from Headsets Direct!
Aug 06, 2010 | Plantronics S11 Headset
No sound coming from my computer but videos play
Check the volume setting and also check that to mute box has been unticked.
Also to test the audio connect a stereo headphone to the headphone outlet on the laptop to see if you can hear sounds.
If you don't hear any sounds - return it, it will be still under warranty.
Mar 30, 2009 | HP Computers & Internet
Motorola Mobility S11-Flex HD Logo
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
