Question about Maytag MSD2756GES Side by Side Refrigerator
Ice maker removal
The arm does not go all of the way down after dumping ice. I want to remove ice maker to fix the problem. I removed the bottom screw but the it is still attached at top and I don't want to force or break it off.
peyton32034
  • 410 Answers
SOURCE: Ice maker removal
first of all remove the ice bucket. then you will see a wiring cover on teh left hand wall just below teh icemaket. there is a rectangular hole in this cover. using a small precision scredriver carefullly insert into this hole and push up or and down to release a hidden clip. the trick is to pull on the wiring cover while you try to maneuver the clip. first time you do it it can be very frustrating but keep working at it and you will get it.
alternately you could just leave the Icemaker in place and use a hairdryer to melt the jammed ie out of the way. good luck peyton
Posted on Jan 28, 2009
aasc
  • 1606 Answers
SOURCE: I have Maytag MTF1954ARA with ice maker which
Pour about 3/4 cup of water into the icemaker . If it dumps the icecubes but doesn't refill with water , then replace the water inlet valve . If it doesn't dump the cubes , replace the icemaker . Make sure the coils are clean down by the compressor also .
Posted on Aug 02, 2009
garing
  • 998 Answers
SOURCE: Ice maker does not make ice. Arm is in proper
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure thefridge coils are clean and free of dust , lint , pet hair , etc....
Posted on Aug 30, 2009
zooless
  • 109 Answers
SOURCE: remove ice tray
check this out!!!
hope it would be helpfull
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=MZD2766GES&mfgModelNum=&fkMfgID=1
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
Posted on Jun 02, 2010
  • 351 Answers
SOURCE: How do you remove ice maker from Maytag
those should unplug from the side of ice maker would will have take front cover off just pry off
Posted on Oct 03, 2010
Why does Whirlpool G16FARXXF05 refrigerator not dump the ice?
as I remember them there is a small heater that warms the bottom of the ice maker so the ice is loosened a little perhaps your timer or heater has gone kaput
Jul 20, 2015 | Whirlpool Refrigerators
MAKING ICE BUT WILL NOT DUMP ICE CUSTOMER HAS REPLACED ICEMAKER TWICE
Super easy fix. Pull out the Ice Maker. Two screws at the top, one ground screw at the bottom. remove plug. Once Ice Maker is out remove the white cover. Again two screws. Check to see if there is ice blocking the control arm. That has been the problem on most of these. Remove Ice, reinstall and enjoy the ice.
Apr 23, 2014 | LG LSC27914
Ice maker control arm has broken and ice machine keeps making ice. How do I stop the icemaker? And, then, how do I fix or replace the control arm (which appears to have snapped at the point that the arm...
Good day,
You will have to remove the ice maker. Usually 2 screws or clips on top and one screw on the bottom, as well as the plug that supplies the electrical power.
Since you'll need a new arm anyway, I would suggest you take the ice maker to any decent sized appliance parts house, and see if they'll pull the the old stub out and install a new control arm.
If that doesn't work, you'll need to replace the whole ice maker.
If you want to see if you can remove the stub yourself, unsnap the front cover. You'll see a semi-solid state type board. It is held in with 3 screws. Remove those, pull the board off, and inspect the area we are talking about. You might be able to get it out, but if not, go back to my first suggestion.
Oct 11, 2010 | Amana ARB9059CS Bottom Freezer...
My icemaker just stopped making ice today....please help
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Aug 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice Make will not Dump into Bucket
The arm that drives the ice out of the freezer tray is driven by a small motor in the front of the ice maker. The motor has a small gear that drives the larger gear keyed to the front of this arm. If the ice is ever allowed to thaw and re-freeze the driven gear can break one or more teeth off affecting the operation of the ice cube removal. None of the parts of the ice maker are available separately. However these parts are easily repaired with super glue or epoxy. When re-installing the drive arm it must be located with the drive fingers horizontal.
Feb 28, 2009 | GE Refrigerators
Ice maker not working
If you press and hold the button on the ice maker for seconds it will go into test mode and do a complete cycle. Try this and it should correct the problem. If you think the arm is frozen, you could use a hair dryer on it for a couple of minutes then do the test.
Sgt 48
May 20, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
GE Monogram ZISS480DMCS Ice Maker Problem
Check and make sure that the float arm in the ice bin is down and able to swing. This arm should be down until the bin is full of ice which would raise the arm and stop any water flow until ice cubes are removed, and allows the arm to drop again to start the cycle all over again, to replace the ice that was used. The arm has a spot to snap in and be held where it would be in a position all the way raised, to allow the bin to come out for cleaning or all of the ice removal from the bin, such as to dump the ice in a cooler. The arm should be gently pulled down to hang freely and will slowly raise on its own as the bin fills with ice.
Jan 02, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Maytag MSD2756GES Side by Side Refrigerator Logo
23 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
