Question about Eureka AirSpeed One Turbo Bagless Upright Vacuum with Turbo Nozzle, AS2011A
Nothing gets sucked up and it has a burning smell
I started vacuuming and the vacuum motor slowed down, then stopped. I smelled a burning smell. Then I discovered the next day that the bag bottom was wet and falling apart. Sebo X4 model
sucked up liquid goes with the air through the motor
that would cause the motor to burn out
with the current low cost of new vacuums , the repair /replacement of the motor would be close to a new unit
take it to an appliance repair shop and get a proper diagnosis and quote
Dec 02, 2016 | Vacuums
Sucked something up and it smells like its burning,nothing in the roller
You have to remove the bottom cover on vac something is jam inside causing the motor or belt to smell
Apr 20, 2015 | Dirt Devil Feather Light Bagged Upright...
How do I remove a duster sucked up in dc04 and cannot find it anywhere?
Hi there, it's Jack at Dyson.
If your DC04 is making a burning smell after picking up the duster, I would encourage you not to use the machine until we can help you locate and clear the blockage, and run you through some quick troubleshooting checks to make sure nothing is damaged.
When you have a moment, please call our freephone UK Helpline when you have your machine to hand. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
We'll look forward to speaking with you.
Sep 21, 2014 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
How to disassemble the brush to empty anything that might be stuck inside of the brush? The motor seems to be overheating, all belts have been checked, all airways are clear and the filter is clean. The...
If there's a burning smell and the belts are fine, the problem is going to be hot wires causing the insulation to melt, or the motor going bad. Discontinue use and have it checked at a repair shop.
Apr 11, 2011 | Bissell 6594 PowerForce Bagless Upright...
When I turn the vacuum on it sounds really loud, louder than usual, and after a few minutes it smells like burning rubber around the canister. The vacuum is still sucking.
The armature is probably missing a plate and the motor is about ready to burn up, but check the filter and screen on the bottom of the motor first. The screen can be checked by removing the filter and looking up at the motor from below. Clean if necessary by removing the motor. Unplug the unit first. If the motor sounds rough and smells like something electrical burning. It's going to need to be replaced. Check your model # and order a replacement. Pretty easy to install if you get the right motor. Get the foam gasket for under the motor if your replacing a three stage motor.
Jun 06, 2010 | Electrolux Centralux Vacuum
Vacuum making high pitched noise and smells like motor is burning
try repair first for quote and if too expensive then replace. 5 years is about the average life span.
Jul 01, 2009 | Dyson DC14 All floors Bagless Upright...
I have a egomaxx 1800 vacuum cleaner which is not 'sucking' up at all well. There is no obvious blockage.
Sometimes the blockage is within the hose itself and not easy to spot. The only thing that can keep a vacuum from sucking is somekind of blockage. It is rare that a motor have lost power because of a short thats why it is not sucking, and it would be very obvious because you would smell something burning.
Jun 27, 2009 | Vacuums
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Eureka AirSpeed One Turbo Bagless Upright Vacuum with Turbo Nozzle, AS2011A Logo
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
