Question about KitchenAid Dishwashers
Kitchenaid dishwasher model kup02ir leaking
Leaking from the front right from white piece of plastic
sadguy
  • 88 Answers
SOURCE: Water leaking from underneath the dishwasher....
yes you can i did on my dishwasher my self it cast aprox 5 or 6 cdn dollers but its not easty to fit it will take time
Posted on Aug 15, 2008
futureloginn
  • 734 Answers
SOURCE: Dishwasher Leaking
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
rpbuice
  • 161 Answers
SOURCE: Washer fills but won't wash or drain yet it cycles KUDM24SEAL1
Check to see if power is getting to the motor. If it is then you have a bad motor. Is the motor making a noise? Some of that broken plastic could have got down into the pump and have it locked up.
Posted on Dec 16, 2008
SOURCE: Dishwasher leaks water from front
posible solution 1) use detergent whitch originally reconmended ( detergent for dish machine only,)
no regular dish wash detergent
2) check gasket and door allianment
Posted on Aug 28, 2009
heatman101
  • 43501 Answers
SOURCE: Our kitchenaid dishwasher is not cleaning well
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Jun 01, 2010
Kitchenaid Hinge tensioner
It is aall exposed on the outside of the unit. Discconecct the water, remove the two set screws attaching the unit to the counter, slide it out and you will see the damage left or right. The white plastci piece slips off over the metal clip and you re-attach the string, apply pressure to the spring and slip the platci piece back over the metal and you are done. You will spend more time removing the unit than repairing it.
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
I have a Kitchenaid dishwasher model KUDS01FLSS2. I finished replacing the door balancer cord and started the dw up and it started leaking underneath from the bottom somewhere around the middle of the...
In this Kitchenaid dishwasher model KUDS01FLSS2, the whole motor and water pump assembly simply sits (I think loose) in the bottom of the DW. From the inside, it is the round mechanism where the sprayer is mounted above the chopper, all one piece sitting in (or mounted with) a large rubber washer around it. Somehow this assembly had lifted up slightly on one side which allowed the water to just poor through the bottom floor of the DW. I simply pressed down on the whole mechanism positioning back in its proper place. It did not take much pressure at all to position it back into its place. This stopped the leak and is working like a charm.
Nov 13, 2009 | KitchenAid Dishwashers
Leak from white plastic box under right side of door
Check the seal around the pipe the plunger runs in. The other thing is to make sure the switch cuts off water fill BEFORE the level gets to the top of that pipe. This could be defective switch or adjustment of it.
The water level should be well below the top of the pipe when filled.
If the switch has gotten wet, it may be defective due to internal damage.
Sep 09, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
KitchenAid Dishwasher (KUDP01FL) - electrical problem
Kill the power to the unit. Pull the control panel down to access the control board located on the right hand side of the panel. There will be 2 wires coming in to a white plastic clip on fuse located on the side of the control board. It will have a plastic pliable shield over it. Pull the 2 wires and check for continuity across this fuse. If no continuity then go to parts house with model number of unit and ask for thermal fuse for your unit. Replace this fuse following the instructions included in the kit and use all the parts included in the kit.
Apr 11, 2009 | KitchenAid KUDR01TJ Dishwasher
Water leaking from under the machine (Miele G638 Plus) dishwasher
The salt tank is a pathetic piece of ****. The plastic cracks and leaks into the bottom tray, which in turn sets off the safety switch.
Follow the attaching hoses and bypass the salt tank unless you really need it. This will save you around $250 for a salt tank and $300 labour for callout and repair.
Mar 23, 2009 | Miele 24 in. G638 Plus Free-standing...
Dec 16, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dec 22, 2007 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
