Question about Sewing Machines
Necchi 6160 bobbin case part number?
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
  • 47 Answers
SOURCE: necchi sewing machine
www.ifixmachines.com has lots of parts fitted to your sewing machine for a cheaper price
Posted on Jul 23, 2009
miket756
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
  • 4 Answers
SOURCE: Where to find Necchi 525FA sewing machine bobbin
Your Necchi uses a generic 15 Class zig zag bobbin case. Jo-Ann Fabrics sells one for White machines that will work for under $5.
Posted on Feb 15, 2011
  • 539 Answers
SOURCE: Necchi model 3537 won't pick up bobbin thread
sewvacdoctor.com has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Posted on Apr 03, 2012
Can a bobbin case be purchased for a Necchi sewing machine Nova esperia Not sure what the model is. There is a number 29-0016972 on the frame.
If you have the old bobbin case, take it and the make/model to the local sewing repair shop. They will either have one in stock or can order one for you.
Apr 14, 2017 | Necchi Sewing Machines
I have a Necchi sewing machine The bobbin thread is way loose. What should I do
Start out with a brand new needle.
Be sure the machine is threaded properly. Also, the presser foot MUST be raised before threading so the thread will seat properly in the tension disk.
The standard setting for the upper tension is the midway point between the high and low number.
If the bobbin thread is still way too loose, you can try adjusting (tightening) the bobbin case tension. If that does not fix the problem, you can probably try purchasing a new bobbin case for your machine as the old one may be broken or worn.
adjust bobbin tension Google Search
Jan 27, 2016 | Necchi Sewing Machines
Necchi sewing maching adjustments
try a new needle
rethread the machine top and bobbin
try adjusting the top thread tension
make sure the bobbin is inserted into the bobbin case correctly
Mar 23, 2015 | Necchi Sewing Machines
I have a Necchi 575FA and the bobbin thread cloggs up.
try changing the needle
also try using a different bobbin just incase there is something
wrong with that one
make sure the thread is wound evenly on the bobbin or this will
cause problems
make sure the bobbin is turned the right way in the bobbin case
Nov 29, 2012 | Necchi Sewing Machines
I have an Necchi and omega sewing machine the model is 6022. I need a bobbin case that holds the bobbin in it and the owners manuel can you tell me the price of each one of them
Go to http://allynint.com/
Get the phone number off the web and call them, they have what you need.
If you speak to Dorothy, or Bob Coen, tell them Merry Christmas from Ellen in Arizona. Merry Christmas to you too,
Dec 24, 2010 | Necchi 6015 Mechanical Sewing Machine
I have a necchi sewing machine. How and where do you insert the bobbin in model 525fa
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
Nov 17, 2010 | Necchi 3101 Mechanical Sewing Machine
Bobbin case on my 524fb necchi has come apart
Dwayne
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
