Question about HP OfficeJet 4255 All-In-One InkJet Printer
My printer HP Office print slow
My printer is printing very slowly' , after I change the cartrige .I whait to print one paper almost 30 min.
Send me drivers, my cd are missing what can i do
Posted on Apr 08, 2008
Hp officejet 4355 all-in-one printer was very slow printing
Ok,if it is slow printing on faxing,than it depence from the sender or from network.But if prints sloly when you copy than try to make it faster on manu display,or try to open it and maybe is some peace of paper left inside and blocking it.
Jul 04, 2014 | HP Officejet 4355 All-In-One InkJet...
Hp M1005 Laser printer showing no print cartridge while I've replaced a new cartridge.
it means you have a paper jam
open up the tray, take the paper out and place back.
switch off printer and turn back on.
i have just found this on the internet myself and I have struggled for a week, but now ok...
May 20, 2010 | HP LaserJet M1005 Printer
Whenever I have a customer tell me their printer seems to be running slower, 9 times out of 10 its what they're trying to print...not the printer. Heres a couple of things to do and ask yourself. First I'd do a test print from the printer itself. Does it kick it right out? Then go to the printer folder on the computer, right click on the printer, go to print test page. Does that come out pretty quick? Okay if they seem relatively fast then its beginning to look like something other than the printer. Try printing the job that seems to run slow. Then try printing from a different program. Is there a difference in speed? The job that prints slow may have graphics or require more memory then it use to. Perhaps you changed the graphics content on the page and the printerr is taking more time to process it. Adding more memory to the printer can help that.
Did you make any software change to the printer about the same time you noticed the slow down?
Have you changed the font color in the computer to something other than black for that particular print job? I've seen monochrome (black and white) laser printers slow down because its trying to convert the job to say violet or some other color. Its a black text printer and apparently printing color confuses it My bet is..if you really sit down and think back...something changed in the content of what your printing thats taking it longer to process it. Hope this helps!
Jul 10, 2009 | Dell Office Equipment & Supplies
Changed cartrige, now have smudge lines on paper
please check the cartridge and see if it is the recommended one the printer..
if it is .... remove it ,clean the print mouth, re fix it and try printing...
sometimes refilled cartridges also give the same problem. please check that too.
May 26, 2009 | HP LaserJet 1020 Printer
Printing is very, very slow
Issue The printer is printing slow. Solution Follow the instructions below to manually select the paper type and print speed.
  1. In the application you are printing from, click File , Print , and then Properties . The Printer Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Change the Print Quality from Automatic to the desired setting.
  4. Change the Type is selection from Automatic to the appropriate paper type that you are printing on.
  5. Click OK .
Mar 03, 2009 | HP - HP Photosmart 8250 printer
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Hp Officejet 7210 all-in-one
Random Extremely slow printing !! same !! changed cartridges . i cant figure out the problem !
Nov 21, 2007 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet 4255 All-In-One InkJet Printer Logo
220 people viewed this question
Ben Johnson
